Username Post: Rocker arm assembly        (Topic#356414)
Airlifter
Airlifter
Reg: 06-07-15
05-14-19 09:10 AM - Post#2766380
Will the rocker arm assembly from a 1954 power glide engine work on a 1958 261? The assembly on my 54 engine only has about 4000 miles on it and I would like to use it if possible.
Thanks, Pete
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
mark50
Loc: SF, CA
Reg: 05-10-04
05-14-19 03:46 PM - Post#2766398
    In response to Airlifter
I think you should be ok, but read this article— it's super helpful!
http://chev235guy.blogspot.com/search/label/235%20...
Early rocker arms on a later motor can lead to crazy oil pressure at the rocker assembly. I experienced that and had oil squirting everywhere when the engine was running and the rocker cover off. It's due to the oiling groove being offset on later rocker arms. Anyway, that article helped me get things back under control!
05-14-19 06:40 PM - Post#2766413
    In response to mark50
I know there is a difference between the early and late years, but I don't know what the difference is. Ram_51 or Gene Schneider would know.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
05-14-19 09:19 PM - Post#2766427
Personally, I'd match up the part numbers in the Master Parts Catalog as a beginning point. Not to say they wouldn't work...but a different part number would indicate some sort of difference. A difference that may translate into improper or poor performance.
1951 Fleetline Preservation
2blu52
2blu52
Reg: 03-12-02
05-15-19 09:06 AM - Post#2766459
It is possible that the shape of some of the rockers may differ depending on the cam and hydraulic or mechanical lifters.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
05-15-19 01:39 PM - Post#2766481
    In response to 2blu52
I had the drilled head bolt in my 62 261. Oil up from lifter galley. Don't recall how oil was transferred to rocker shaft up top on head.
Tom
48 sports coupe
63 C-10 long fleet
17 Tacoma double cab longbed
17 Toyota Rav-4
Been down most all the roads nowhere left to go??
Execution time: 0.102 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:27 AM
