Username Post: Need help from TBI owners        (Topic#356402)
05-13-19 11:03 AM - Post#2766297
Can someone with a TBI setup measure their TV cable system? I need the measurement from bracket to TBI throttle stud. I'm looking for a TV cable replacement cable. A cable without universal end stop. A stock setup has a crimped cable stop. The TBI distance is similar to a TPI setup. The difference is cable length. Approximately 5". The distance will determine if I can use a TBI cable for my setup. The height and distance is different from stock. The RPM Air Gap intake is tall. The bracket is bolted to the rear left intake bolts. The distance on my setup is ~5 3/8".
Attachment: cable1.jpg (145.01 KB) 12 View(s)
BADBOW setup.
Attachment: cable2.jpg (93.54 KB) 18 View(s)
Bracket to throttle stud distance.
06-09-19 05:23 AM - Post#2768014
Attachment: InkedTBIcable_LI.jpg (60.45 KB) 10 View(s)
Thanks to riccon and Texasray for TBI info help. I have the measurements needed. A TBI factory cable with a crimped end should work on my ZZ4/RPM Air Gap intake set up.
Execution time: 0.1 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:14 AM
