Username Post: Bouncing Speedometer        (Topic#356352)
ChipB
Reg: 03-13-19
05-09-19 12:28 PM - Post#2766029
The speedometer in my 1962 C10 works fine about half the time. The other half the time, it makes a grinding noise and the needle bounces around. Often when bouncing it only bounces about 10mph either way. But sometimes, it will bounce all over the speed range. (From 0 to 80 or 90 when doing only 35mph) The noise sounds like it is coming from under the dash or in the dash itself. (Hard to tell because I'm always driving when it happens.) Has anyone experienced a similar problem? I'm guessing the easiest thing to do is replace the speedometer cable. If that's not it any ideas?
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
05-10-19 04:10 AM - Post#2766078
    In response to ChipB
Sounds like the cable needs lubrication or replacement. Try removing the cable and coat it with graphite (speedometer lube). Make sure the cable housing isn't kinked anywhere. If lubrication doesn't correct it, replace the cable. Last resort is replacing the speedometer head if the cable isn't the problem.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
Execution time: 0.067 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:10 AM
