Username Post: Bouncing Speedometer        (Topic#356352)
ChipB
Reg: 03-13-19
05-09-19 12:28 PM - Post#2766029
The speedometer in my 1962 C10 works fine about half the time. The other half the time, it makes a grinding noise and the needle bounces around. Often when bouncing it only bounces about 10mph either way. But sometimes, it will bounce all over the speed range. (From 0 to 80 or 90 when doing only 35mph) The noise sounds like it is coming from under the dash or in the dash itself. (Hard to tell because I'm always driving when it happens.) Has anyone experienced a similar problem? I'm guessing the easiest thing to do is replace the speedometer cable. If that's not it any ideas?
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
05-10-19 04:10 AM - Post#2766078
    In response to ChipB
Sounds like the cable needs lubrication or replacement. Try removing the cable and coat it with graphite (speedometer lube). Make sure the cable housing isn't kinked anywhere. If lubrication doesn't correct it, replace the cable. Last resort is replacing the speedometer head if the cable isn't the problem.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
1oldtimer
1oldtimer
Loc: Orange County, Ca.
Reg: 08-08-04
08-20-19 12:42 AM - Post#2773623
Or the speedo head itself needs to be greased. My '64 panel used to do that when it was cold outside.
'60 Chevy El Camino
'60 Studebaker Lark Wagon
'59 Hillman Husky (2-because you need parts)
'56 Chevy Panel truck
'47 Ford 2dr Super Deluxe
'41 Ford Pickup
'36 Ford 5w coupe
'28 Ford Tudor
They're all projects in some form.
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
08-20-19 05:03 PM - Post#2773699
    In response to 1oldtimer
ChipB
This was written for a different vehicle but the guts are very similar when you get inside.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
ChipB
Reg: 03-13-19
08-20-19 07:44 PM - Post#2773714
    In response to WagonMan
Thanks for the feedback all. I replaced the speedometer cable but that didn't fix anything. But with time the bouncing has greatly decreased and the noise has stopped. Of course, the odometer has stopped too. (Stuck at 59999.9) So, I'm pretty sure that the odometer is frozen and that whatever gears were in there are stripped by now. So... I guess I'm in the market for a 1962 odometer. More than likely I'll have to find a used dash from somewhere.
Execution time: 0.118 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:23 AM
