Username Post: Correct light bulbs        (Topic#356336)
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
05-08-19 07:46 AM - Post#2765943
What are the correct light bulbs for the tail and brake lights on a '36 sedan? Also, are there any 6v LEDs that will fit/work?
thanks
Ken
36, 38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
http://www.picturetrail.com/ken
Edited by bowtiefan on 05-08-19 07:48 AM. Reason for edit: No reason given.
Chevs of the 40s
2blu52
2blu52
Reg: 03-12-02
05-08-19 03:37 PM - Post#2765966
    In response to bowtiefan
Check The Filling Station" on line cataloug they have lots of stuff there.
THOMAS JEFFERSON
Ray P W
Reg: 09-30-15
05-08-19 05:53 PM - Post#2765970
    In response to 2blu52
Ken,
Contrary to "expert" statements to the contrary there are halogen bulbs that a '36 generator can power no sweat. I have them in my '36 PU. Here's more on that subject:
https://www.ply33.com/Repair/lights
I'm in Santa Rosa (Sonoma County) so we're practically neighbors.
Ray W
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
05-08-19 10:09 PM - Post#2765989
    In response to Ray P W
Ray, thanks and I will study that more, but my concern at the moment is with the tail/brake lights. The Filling Station only has 12v LEDs and the other bulbs all say brake, tail light or turn signal, so I assume that they are all the same brightness. I may be wrong, but I would think the brake light would be brighter than the tail light bulb, but maybe the thought was just an extra bulb was enough. That's why I'm asking the question.
Ken
1971BB427
1971BB427
Loc: Portland,Or
Reg: 12-06-09
05-09-19 05:22 PM - Post#2766052
The correct number for the tail lamp bulbs should be 1158. Same as 12 volt 1157, except the last digit.
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1946 Austin gasser 327/TH350
http://img.photobucket.com/albums/v691/marlinguy /D...
http://www.hunt101.com/data/500/medium/DSCF3 906.JP...
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
05-10-19 11:57 AM - Post#2766114
    In response to 1971BB427
The 1158 bulb is a double element bulb. The 36 Chevy requires two single element bulbs, one each for the tail light and brake light.
Ken
Ray P W
Reg: 09-30-15
05-11-19 10:45 AM - Post#2766173
Ken,
If you find bright 6 volt LED bulbs would you mind passing that information on to me?
The link I sent you has information on how to upgrade your generator with a real voltage regulator that hides inside the generator. It is a HUGE improvement and makes your generator work like a normal generator or alternator. Instead of making less current as it revs up it will make more and it reduces the charging rate as the battery becomes more fully charged.
It's amazing to me that the "originality" stuffed shirts shun that part because it's not "original". It makes no difference to them that it's totally hidden inside the generator.
Most of them definitely did not approve of this project that I did:
https://vccachat.org/ubbthreads.php/topics/334876/...
I guess that improving function makes no difference on a trailer queen.
Ray W
Edited by Ray P W on 05-11-19 10:47 AM. Reason for edit: No reason given.
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
05-11-19 11:57 AM - Post#2766177
Ray, I'm still looking for a LED bulb that will fit. Most are too long and/or double element, so for now I'm just using a T63 6v bulb for the brake, and the T83 which I'm told is 12v and came in the car, for the tail light.
Ken
1971BB427
1971BB427
Loc: Portland,Or
Reg: 12-06-09
05-14-19 05:41 PM - Post#2766401
If they're single filament on a '36 then they're 1129 lamps.
BearsFan315
Loc: Virginia
Reg: 12-12-12
05-15-19 03:30 PM - Post#2766489
for LED bulbs look at Restoration Supply Company, they have a good selection of 6v & 12v LED bulbs for older cars. I have attached Page 09 Bulbs & Page 10 LED Bulbs from the catalog i have from them
hope this helps some... i get general bulb info for wattage, candel power, base, etc from Bulbtown
Restoration Supply Co Pg 09
Restoration Supply Co Pg 10
AACA - VCCA - Stovebolt - ChevyTalk
Love the Antique Chevrolet's from 1928-1932
The Beauty, Simplicity, History, and the Stories they Tell
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
05-21-19 08:14 PM - Post#2766901
1971BB, no disrespect, but you obviously aren't familiar with a 36 Chevy. The 1129 bulb is far too big. The T63 that is in it now, just barely fits. It's a hair over 1" long. The 1129 is 2" long. These are not much bigger than a dash light bulb.
Ken
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
05-21-19 08:15 PM - Post#2766902
    In response to BearsFan315
BearsFan, I see that they may have what I want, but I will have to call them to verify the overall length. Thanks, Ken
Chevs of the 40s
Execution time: 0.144 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:33 PM
