Username Post: Popping thru exhaust        (Topic#356326)
Mdgolf66
Loc: Michigan
Reg: 03-13-18
05-07-19 04:02 PM - Post#2765905
Hello, thanks in advance for advice. I live in Michigan so !st fire up of the year was just last week. I' getting an inconsistant loud pop out of my drivers side exhaust during high idle, especially when cold. I replaced plug wires,still have it. Replaced plugs with same as what came out last year, no problems last year. A mechanic friend said maybe a plug firing late. So I replaced each left side plug one at a time and started it between plugs and still have the popping. 454 cid,hei. Any ideas
05-08-19 04:05 AM - Post#2765925
    In response to Mdgolf66
Turn it on at night. Or when there is less light. Check for arching. It can be a non firing plug with unburned fuel igniting in the exhaust pipe. Check that each wire is firing. You can use a timing gun to check each wire.
'08 GMC Acadia 3.6L SLE
05-08-19 06:45 AM - Post#2765936
Lean mixture or vacuum leak are the most common causes assuming the engine is up to par mechanically.
05-08-19 09:49 PM - Post#2765985
might try a cold compression test
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
05-10-19 11:49 AM - Post#2766112
    In response to bobb
Might even be a sticking exhaust valve.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
corvesy
corvesy
Reg: 08-07-08
05-13-19 06:46 AM - Post#2766273
    In response to WagonMan
Look at each spark plug and see if you can see one that's not firing. If so inspect the plug wire closely. Sometimes the plug wires can fail internally.
Execution time: 0.15 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:47 PM
