Username Post: Gas cap        (Topic#356325)
Am4wag
Reg: 11-19-15
05-07-19 03:47 PM - Post#2765903
My 69 has big block power now with a Carter mech.fuel pump that has a return.I installed a sending unit that has provisions for a return line (extra barb on top).But every time I fuel up pressure gushes out when I remove the cap.I am using a vented fuel cap for a 70 Chevelle,but still...………..what cap do I need?
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
larrybrowningmauldin
Loc: New Braunfels,TX
Reg: 08-16-05
09-20-19 07:16 AM - Post#2775951
    In response to Am4wag
Maybe the vents on the gas cap are clogged. I had a similar situation and just drilled the holes larger (off the car, of course). Now my garage smells better.
Execution time: 0.116 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:07 AM
