Username Post: 78 L82        (Topic#356280)
Jim.Biron
Jim.Biron
Loc: Monterey, TN
Reg: 04-10-08
05-03-19 11:06 AM - Post#2765635
Does the L82 motor look any different than the other 78 model year motors? ie: valve covers, air cleaner, etc
Any different in the Indy or Silver Ann car?
www.HudsonValleyCruise.com
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
05-20-19 04:00 PM - Post#2766820
    In response to Jim.Biron
L48
Engine serial number began 0001001
Corvette engines have the last six digits of the VIN stamped on the block just ahead of the cylinder head on the right-hand side combined with a three-letter engine code suffix
Also cast into the top rear of the block is a four-symbol code indicating when the engine was built
The first letter of the date code shows the month the block was cast
The one or two numbers shows the month
The last digit shows the year
Engine suffixes: Code Engine Horsepower Compression Transmission Fuel Supply Emission Control System
CHW L48 350-cid 185-hp V-8 8.2:1 manual four-barrel carburetor
CLM L48 350-cid 185-hp V-8 8.2:1 automatic four-barrel carburetor
CLR L48 350-cid 175-hp V-8 8.2:1 automatic four-barrel carburetor California
CLS L48 350-cid 175-hp V-8 8.2:1 automatic four-barrel carburetor high-altitude
CMR L82 350-cid 220-hp V-8 8.9:1 manual four-barrel carburetor
CMS L82 350-cid 220-hp V-8 8.9:1 automatic four-barrel carburetor
CUT L48 350-cid 185-hp V-8 8.2:1 automatic four-barrel carburetor
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Execution time: 0.098 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:04 PM
