44 Years of Service
Username Post: What parts are needed for 500 box fitment on a 59 chevy        (Topic#356248)
tikiwagon
tikiwagon
Loc: dorset, england
Reg: 04-23-04
05-01-19 11:47 AM - Post#2765480
Hi I bought a CPP 500 box from you you about a year ago,What parts are needed for 500 box fitment on a 59 chevy, I have the original drag link from the old stock box, the stock idler arm which is almost brand new and a manual steering center link, I see you do steering linkage kit but do i need all this?, can i use a idler arm conversion bracket and will my other parts fit(Center link and drag link)
tikiwagon
tikiwagon
Reg: 04-23-04
05-03-19 01:50 PM - Post#2765655
    In response to tikiwagon
Any help on this would be great as i need to re assemble this, thanks
cpptech
cpptech
Loc: CA. USA
Reg: 12-08-06
05-20-19 03:08 PM - Post#2766821
Hi Tiki, you can use the OEM style manual idler arm, center link and pitman arm. You may want to upgrade to the tie rod style and get away from the steel ball though. You will also need a new rag joint, you can use RJC-605L and cut your steering shaft. Or use a new shaft 55020-B and rag joint CP59065, these are bolt in. Then all you need are the hoses, pump, pump bracket and pulley.
Thanks,
Aaron @ Classic Performance
800-522-5004
Execution time: 0.156 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:49 PM
