Username Post: Shop Door        (Topic#356223)
04-29-19 02:12 PM - Post#2765307
My shop roll up door counterbalance spring broke. Anybody ever change one of these monsters? Its like 17' x 17'
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
04-29-19 02:42 PM - Post#2765309
    In response to bobb
pictures would help,
the springs are not that hard to replace and don,t cost a great deal,
https://www.expressgaragedoorparts.com/?gclid=EAIa...
https://www.homedepot.com/b/Doors-Windows-Resid ent...
https://www.youtube.com/watch?v=5k9qrgZ9rPs
but you may want to call a garage door company for the parts and replacement labor,if your not familiar with the deal
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
05-01-19 08:52 AM - Post#2765472
    In response to grumpyvette
Save yourself some time and maybe even some money and have an over head door company do it. Don't ask me why I think this way!
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
05-08-19 10:25 PM - Post#2765991
this door is allot bigger than a garage door. just got a quote at 1030 pm. 5.2k im probly gonna do this one myself with a bit of help. everyone says get a pro to do it. well the last pro mounted the drive motor assembly half assed. i see this kinda crap all the time. i am not a pro at this but im sure that i can get very good results if i apply myself. its what i have always done and its made me who i am. and 5.2k is a whole bunch of lunch money.
65_Impala
Reg: 12-29-02
05-10-19 04:46 PM - Post#2766138
    In response to bobb
Wow, $5200 to replace a spring. That should get you a whole new door. I've done a few, but not on a door that big yet. I's not terribly difficult. Just go slowly and methodically. Make sure you have long enough winding bars and that they fit snugly into the winding holes. Make sure each bar bottoms in the hole when you move it as you are winding. I would suggest clearly marking the bar so you can can tell when it's in all the way. Use a solid ladder and keep back from the spring and out of line of anything that can spin or fly apart. Never use a socket or boxed end wrench on the set-screws so the wrench doesn't become a projectile.
Figuring out what direction to wind - Face the spring coil end you're winding at with the wire end at the bottom. The direction the coil end is facing is the direction to wind. If it points right then you wind it right or clockwise. Wind left if it points left. Generally, if the spring end to be wound is at the left side of the spring with the end attached to the wall on the right side then you wind the spring right.
As far as number of turns. count the number of times the cables go around the pulleys and wind the spring about that number, maybe 1 more turn. Test it, it should drop when lifted opened a foot or two but not be very heavy to lift open. If the door starts opening by itself at any point through the travel then it's wound too tight.
Google garage door spring replacement and you can find more good info than you could ever view or read.
08-09-19 07:03 PM - Post#2772846
    In response to 65_Impala
well its actualy 2 springs. the big one is about 100 pounds. finaly found someone who would make them for me. many thanks to Karl at Diamond Wire Spring Company. goterdun for less than 1300. shipping was killer. reconfigerred the motor mount so it wouldnt do the death wobble. fixed the motor brake and the gearbox oil leak. it was an interesting project. i like doing different stuff than my everyday grind.
Execution time: 0.126 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:13 PM
