Username Post: Want to send neg when lose power...relay        (Topic#356217)
56_Kruiser
56_Kruiser
Loc: St. Augustine, Fl
Reg: 09-23-05
04-29-19 09:59 AM - Post#2765286
I want to have a relay that when a particular circuit loses power that it sends a negative to the output wire. I was told to wire it like this:
85 and 87a -> Ground
86 -> Power (NOTE: I am using this terminal as the one that I want to monitor. So if it loses power, the end result is that the relay has no power on any ports)
30 -> Output (I have wired this to the negative side of an indicator. So when I lose power, which is the power on 86, then a gnd gets sent here)
I find it to not be working.
Have I misunderstood the instructions I received?
Any help appreciated very much.
1956 Chevy
Vid of 61
61 Chevy
Senior Chevytalk Moderator
04-29-19 10:26 AM - Post#2765291
    In response to 56_Kruiser
Ok, I'm confused.
Wouldn't you need two relays?
04-29-19 11:37 AM - Post#2765294
Is the indicator using the same power as 86?
04-29-19 01:41 PM - Post#2765302
    In response to acardon
For my 165 amp alternator, I have a dash light in the circuit. It lights up when the alternator is not charging. It's the exciting wire to get it started. Once the alternator kicks on to charge, the light turns off.
Are you trying something similar?
56_Kruiser
56_Kruiser
Reg: 09-23-05
04-29-19 01:59 PM - Post#2765304
  • gchemist Said:
Ok, I'm confused.
I don't know...you tell me. I had posted on the12volt.com forum, and was provided with that method.
The thing that I have felt suspicious of this method is that the relay ends up with no power. But I thought, well, it needs to just send a ground...so maybe no power needed...maybe the power on 86 is what is keeping 87a from sending the ground out 30.
No.
Yes. Here's what I'm trying to do:
I have had fuse blow and end up with no brake lights in the past. So, I want to know if the fuse to the brake switch blows.
I have a Dakota Digital dash in my '61, and it has a port on the controller to put a negative to that turns on the brake warning indicator. The intention of the light was for the emergency brake...but I don't have a switch on it, and figured this would be a great use for that.
[EDIT]
I find that the relay is warm. I'm sure it is hot all the time, and draining on battery. I definitely need a different solution...maybe 2 relays.
1956 Chevy
Vid of 61
61 Chevy
Edited by 56_Kruiser on 04-29-19 03:04 PM. Reason for edit: No reason given.
04-29-19 03:08 PM - Post#2765310
86 -> Power
30 -> Output
You realize that with the brake switch (constant power) connected to 86 and 85 grounded, the relay will stay energized 24/7 and run the battery down.
That said, it looks like it should work.
Does the indicator light come on when 30 is grounded? Check for continuity to ground on 30 with the brake fuse pulled.
86 is connected to the fuse side of the brake switch?
I missed your edit.
Edited by acardon on 04-29-19 03:12 PM. Reason for edit: No reason given.
56_Kruiser
56_Kruiser
Reg: 09-23-05
04-29-19 05:38 PM - Post#2765336
Well, update....
I find it working although I think intermittently. I must have a loose/poorly made connection. I can chase that.
But, I am left with want of a way to do this without a constantly hot relay using up battery all the time. Is it possible?
1956 Chevy
Vid of 61
61 Chevy
04-29-19 06:53 PM - Post#2765342
As mentioned, a second relay to provide a ground to 85 of the first relay.
Second relay:
85 to switched power
86 to ground
30 to 85 of 1st relay
87 to ground.
This will keep the 1st relay from energizing until the key is turned on, then both relays will energize. When 86 of the 1st relay looses power, 30 will go to ground and turn on the indicator light.
56_Kruiser
56_Kruiser
Reg: 09-23-05
04-29-19 07:13 PM - Post#2765343
@acardon...thanks! You've brought lots of answers to me, and others too. I really appreciate it.
I'll introduce another relay. (I have quite a few in that car).
1956 Chevy
Vid of 61
61 Chevy
65_Impala
Reg: 12-29-02
05-02-19 09:58 AM - Post#2765552
Move 85 to another constant power source and ground 87 instead of 87a. Then, the indicator will come on when the fuse is blown and the brake pedal is pressed - the relay coil will be grounded by the brake lights when the brake pedal is pressed. It's a one relay solution and the relay is only energized when the pedal is pressed while the fuse is blown.
56_Kruiser
56_Kruiser
Reg: 09-23-05
05-07-19 05:50 AM - Post#2765872
    In response to 65_Impala
Thanks! Done...
1956 Chevy
Vid of 61
61 Chevy
05-07-19 08:08 AM - Post#2765879
So you used only one relay? Or two?
05-08-19 10:34 PM - Post#2765993
whynot just use a circuit breaker?
WagonCrazy
WagonCrazy
Reg: 06-07-05
05-11-19 06:39 AM - Post#2766166
    In response to bobb
Here's a great resource on all kinds of relay wiring diagrams, for many different automotive scenarios...
the12volt
Execution time: 0.074 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:24 AM
