Username Post: Torched Coil Spring        (Topic#356207)
vabeach56wagon
vabeach56wagon
Loc: Chesapeake,VA,
Reg: 04-22-02
04-29-19 08:31 AM - Post#2765274
My current project has a discernible 1/2" left lean at the rear. Right front is equivalently high. Apparently the previous owner used a torch on new springs to drop front down at least an inch...but missed the mark a bit on the right front.
I have replaced all rear spring hangers, pads, bushings, shackles.
Advice is requested: do I take my torch and heat the coil which is most collapsed and if so, where on it and how do I limit the amount of drop?
Or do I have to bite the bullet and buy new coils, which may or may not need some massaging?
paul
Original builder of the Gobstomper - '56 210 9 passenger wagon now in other's hands. Current Ride is '69 X33D80 Z28 Camaro
04-29-19 10:10 AM - Post#2765289
    In response to vabeach56wagon
I think your aware, the back can still cause the front to appear to sag. Determine if it's the front or back by jacking the front up on a pipe running longways in the exact middle of the front crossmember. Then measure the back from the frame to the axle housing. http://www.trifive.com/garage/56%20Chevy%20A ssembl...
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
04-29-19 04:02 PM - Post#2765321
I would use Acardon's method after I changed the front springs. Reason is with heating a spring you heat/weaken areas in both directions past where you aimed the torch. Even if the car sat 100% square now I would still switch out those front coils.
Or if you have not heated coils b4 do Acardon's method first then heat up the rt coil and watch for results. Don't let shock get too warm.
Report back once you get the fire knocked down.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
04-29-19 04:22 PM - Post#2765324
    In response to Mel Foye
Torching coil springs is absolutely the worst method available. Don't do it. Worst ride and tire wear. Drop spindles is the only method that doesn't mess up the steering geometry.
04-29-19 05:34 PM - Post#2765335
    In response to Tri5man
The problem with torching the springs is twofold.
First, it's nowhere near exact on the results as you already know.
Second, the spring is heat treated - except the part that's been torched. That part will continue to change with time and use.
Just get some new springs and if the ride height is too tall, cut coils to make a fine adjustment. Or put a rubber spacer under the spring if too low, for a fine adjustment. Even original stock springs are fine as long as they don't have pitted rust. Contrary to popular belief, they don't change over time without intervention.
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
04-30-19 03:13 PM - Post#2765404
    In response to Rick_L
Coil Springs
OEM & Custom • Manufactured By EATON Detroit Spring
embossed
Improve your ride quality, stance, and handling with one purchase: coil springs designed to suit your vehicle.
Automotive professionals and enthusiasts the world over swear by EATON springs for our commitment to quality and accuracy in our spring design and production process.
Whether you need coil springs for restorations, resto-mods, hot rods, modern vehicles (like lowering springs for the Ford Crown Victoria), or even custom applications, we will provide springs that fit your needs.
Coil Springs Built With The Original Blueprint
We have thousands of blueprints for American vehicles manufactured over the past century, which is why we’re the number one leaf spring manufacturer for the restoration, street-rodding, and resto-mod industries. Our springs will literally have your vehicle sitting like the first day off the lot, no matter what year that was. Request a quote for your restoration project, order springs from our online database, or give us a call to learn more about how we can help you restore your vehicle’s suspension.
Custom Coil Springs To Lift Or Lower Your Vehicle
Your vehicle’s suspension was built to work with a specific spring and designed to sit your vehicle at a certain ride height. Every year we redesign thousands of springs to adjust the ride height, both up and down, to match what customers would like it to be. And we do this without sacrificing ride quality. Most applications can be raised or lowered a maximum of 3-inches. If you have a question regarding a custom leaf spring design, feel free to contact us.
For A Great Stance, A Great Ride Quality, and A Long-Lasting Suspension
Shotpeened SAE 5160 Spring Steel gives our coil springs a smooth-as-silk ride quality that will last longer than competing manufacturers.
We can design a custom stance (up to 2″ raised or lowered) or manufacture an Original Factory Blueprint Perfect set of restoration springs (your vehicle will sit just like it did out the factory!)
Installs are quick and easy since each spring is designed to fit your vehicle
Ride away safely with new, structurally sounds coils instead of old, worn out ones like those ones to the right — >
If Your Springs Look Like These, Order New Ones IMMEDIATELY!
Most Popular Coil Spring Tech Questions
How & When To Cut Coil Springs
How Much Do New Coil Springs Settle?
Do I Need New Coil Springs?
The Correct Springs For Your Vehicle
Over 24,000 OEM Spring Blueprints
166,000+ Stock Spring Applications
Design Staff Available For Custom Applications
Spring Experts Since 1937
Made in Detroit, Michigan
Made in the U.S.A.
The Many Ways To Order Your Springs:
Call Us at 1 (313) 963-3839
For Quickest Order Completion
Email Us
For When We’re Out
Fill Out Our Quote Request Form
For Less Back-And-Forth
Order Online
If You Want To Place Your Order Immediately
Fax It In at 1 (313) 963-7047
If You Still Have One Of Those
Need Spring Wisdom?
Just ask the Spring Guru!
We love helping with any leaf or coil spring problem.
WARNING:
This product may contain chemicals known to the State of California to cause cancer, birth defects, or other reproductive harm.
www.P65Warnings.ca.gov
05-01-19 10:30 AM - Post#2765475
    In response to pauldian
Now that you've posted an ad, I'll post a counterpoint.
A guy I know bought some Eaton Detroit springs for the front of his 57 a few years ago. The ride height was too short, not necessarily the look but the tires rubbed the fenders. He decided recently he'd had enough, ordered some new springs from them to raise the front. First set he got raised it too much. Sent them back, next set raised the front even more (gasser look, not what he wanted). Throughout the whole process, they told him how stupid he was.
He now has a rubber coil spring spacer under the original replacements and it's doing pretty good. Still low stance but not rubbing, what he wanted.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
05-01-19 03:16 PM - Post#2765490
FWIW, here is my experience with Eaton Spring. I purchased some rear leaf springs form one of the low cost catalog parts sellers and they failed very quickly. I then ordered some from Eaton and after talking with the sales rep, we decided on a spring for my car. I wanted the ride to be stiffer and the car to sit lower. The springs were perfect and have been for about 10 years of use.
05-01-19 07:57 PM - Post#2765507
    In response to 5Larry7
Something I heard about the company is that the founder has passed on and the company is now run by his heirs. Things may not be what they once were.
I do know this. I called them several years ago and I was not satisfied with what I heard on the other end. The guy I talked to seemed to care less about my needs or whether he even sold me anything. I declined to buy anything.
Mel Foye
Mel Foye
Reg: 09-29-00
05-01-19 11:33 PM - Post#2765513
Tri5man and Rick did I lead you two to think I was suggesting heating a spring as a fix rather than a lesson if you had never done it? Since the springs had been heated b4 I saw them as just junk to be pitched.
I know there is a Moog listing of springs here in CT somewhere but I am drawing a blank. Either of you know where?
pauldian
pauldian
Reg: 05-14-09
05-02-19 08:01 AM - Post#2765545
Larry:
I purchased front coil springs from them around sixteen years ago (3" drop). As I remember they were very professional. Still driving with them on the car as of today.
This was a long time ago, some thing change and some things don't.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
05-02-19 08:20 AM - Post#2765547
  • pauldian Said:
Larry:
True enough
Execution time: 0.115 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:10 PM
