Username Post: 1953 3100 / master cylinder / brake line        (Topic#356162)
Woogeroo
Woogeroo
Loc: what does this part do?
Reg: 05-26-02
04-25-19 04:33 PM - Post#2765031
Hiya folks.
1953 Chevrolet 3100 series(half ton) pickup
I am trying to replace all of the brake lines as I had a rupture last year, I have all of the lines removed, finally.
I had to take the MC off the truck in order to get this brake line loose.
I have questions about the line that goes into the back of the brake master cylinder, it has a thread on it, then it passes through the brass piece on there.
Can I buy a new brake line with this thread on it? I've never seen a brake line quite like this before, so I'm guessing the parts store people will be equally confused.
Any help on terminology or a parts source is appreciated, thank you.
-Woogeroo
folder of brake line photos
mc still mounted with brake line
MC / brake line
brass piece on brake line
brass piece / brake line
mc / brass piece / brake line
brake line / brass piece
Edited by Woogeroo on 04-25-19 04:37 PM. Reason for edit: No reason given.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
05-03-19 09:38 AM - Post#2765625
    In response to Woogeroo
The part with the threads on it with the brake line attached doesn't break down any further?
1951 Fleetline Preservation
Woogeroo
Woogeroo
Reg: 05-26-02
05-09-19 03:57 PM - Post#2766043
    In response to RAM_51
RAM_51,
yes, it does, but I didn't know that at the time I posted the question. I suspected it did, but I had never worked on any chevy brakes this old, so I wasn't sure.
I put the bolt in a vice and took a pair of vice grips to the corroded brake line side, where the nut was rounded off... after a few attempts with the old metal on the brake line flaking off, finally got down to some good metal with a grip and the brake line nut broke loose. Then I was able to take it apart and clean it up.
-W
RAM_51
RAM_51
Reg: 12-28-02
05-10-19 04:37 AM - Post#2766079
Execution time: 0.135 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:01 AM
