Danchuk
Username Post: 57 powerglide linkage adjustment        (Topic#356085)
srwhite57
Loc: Tyler, Texas
Reg: 01-10-07
04-19-19 12:05 PM - Post#2764588
Body shop took out engine & powerglide when painting car and when reinstalled it will not go into reverse. There is not enough travel in the linkage. We can disconnect the linkage and get it into reverse manually. Everything worked fine before pulling engine. What could have gone wrong? Car is totally stock, 283 powerpack & powerglide.
04-19-19 02:28 PM - Post#2764593
    In response to srwhite57
The swivel joint on the lever at the bottom of the column, is probably out of adjustment. Worn grommets can make the adjustment very critical as you loose motion. See adjustment sequence.
Link to linkage.
srwhite57
Loc: Tyler, Texas
Reg: 01-10-07
04-21-19 10:43 AM - Post#2764740
    In response to acardon
Thanks, I'll give that a try and post back.
srwhite57
Loc: Tyler, Texas
Reg: 01-10-07
04-25-19 01:12 PM - Post#2765023
New bushings did the trick. Thanks for the suggestion.
57210sportsedan
Loc: Germany / Georgia (US)
Reg: 02-06-03
05-17-19 12:00 AM - Post#2766587
Exact same thing happened to me! In my case it was the transmission mounts. Loosening the bolts, jacking under the tailshaft and re-tightening did the trick. Old worn mounts will evidently give you this problem from one day to the next too.
Markus
57 Chevy 210 Sport Sedan
70 Triumph Spitfire
bought and sold a few more ...
Execution time: 0.106 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:07 PM
