Username Post: No running lights        (Topic#356031)
duggerinc
Loc: Redoak, TX
Reg: 11-08-08
04-15-19 02:11 PM - Post#2764287
Hello everyone. I just bought a 98 3500. 7.4. It need lots of work, and the first issue I want to tackle is the running lights. The dimmer switch is out and needs replaced. The headlights come on when you turn the switch on to the running lights, then the brights when I flip it on. Do the running lights run through the dimmer switch as well? I figured if I replace the headlight switch the running lights should work. But I'm not sure and dont want to waste the money as funds are a bit tight. Any advice would be great, thanks
Edited by duggerinc on 04-15-19 02:12 PM. Reason for edit: No reason given.
duggerinc
Loc: Redoak, TX
Reg: 11-08-08
04-15-19 03:47 PM - Post#2764290
    In response to duggerinc
Never mind. Got it figured out
duggerinc
Loc: Redoak, TX
Reg: 11-08-08
04-23-19 11:25 AM - Post#2764878
Ok so the guy I bought this truck from ran 2 little led fog lights off a relay, attached to the hot wire for the blinkers on the passenger side. I replaced the light switch and the turn signal switch. They running lights worked once or twice and then quit. I disconnected the relay to the fog lights and still not working. Took all the wiring for the relay and fog lights out, taped up his splice and still not working. 2 of the connections on the turn signal plug are burnt up pretty bad, I have pictures but cant figure out how to upload them. I'm thinking I burned the new turn signal switch up since the fog lights were still on the circuit. Any suggestions?
04-23-19 07:22 PM - Post#2764895
http://www.chevytalk.org/fusionbb/showforum.php?fi... Posting photos by Tony
29-41, 42-48, 49-54 Moderator
Execution time: 0.139 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:06 AM
