Username Post: Power steering assembly        (Topic#356018)
Lunar
"3rd Year" Gold Supporting member
Lunar
Loc: Western Australia
Reg: 06-19-16
04-15-19 03:00 AM - Post#2764245
Hi
I have been on the hunt for a vibration I get once I hit 70mph front the front right hand side. I have checked wheel bearings, had the tyres balanced, replaced all the bushings that had deteriorated away, replaced the suspension shocks and coils and am running out of ideas. I am wondering about the ball joints, but not sure if there is a way of testing this first? If anyone has any tips I would be great full.
One item have noticed is what appears to be a missing or worn bush between the power steering control valve and the pitman arm.
From the attached picture of mine, there appears to be nothing there. I have looked for the part from suppliers but can't find it. Shopuld mine be in better condition than shown?
Dan
Attachment: IMG_1157.jpg (2.45 MB) 0 View(s)
My Power steering control valve
Attachment: IMG_1158.jpg (959.15 KB) 0 View(s)
Manual indicating a bushing
63 Chev Bel Air
brokenspoke
Reg: 02-28-08
04-15-19 05:48 AM - Post#2764252
    In response to Lunar
I think that what your calling a bushing is a rubber seal...
omarine
Loc: San Diego
Reg: 06-29-15
04-15-19 05:51 AM - Post#2764254
are you running drums? I ran mine for 35k mi and just put discs on. I noticed a difference...sway bar tight?
the circled part is a seal - if it's not leaking, then it's ok. those need to be torqued precisely or it will leak.
cheers
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
Edited by omarine on 04-15-19 05:53 AM. Reason for edit: No reason given.
Execution time: 0.067 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:12 AM
