Username Post: Positive Battery Cable Route to Solenoid on 64 impala 327        (Topic#356017)
Ascendco
Reg: 01-28-19
04-14-19 08:15 PM - Post#2764236
Trying to figure how the battery cable goes to the solenoid, the assembly manual shows a diagram but it's kinda confusing. Does the cable go between the fuel pump and engine mount, do the clips bolt on to the oil pan?
64 Impala
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
04-14-19 08:47 PM - Post#2764237
    In response to Ascendco
The cable to the starter solenoid is attached to the inner fender under the plastic push in clips with 2 mounting pins per clip, then over the frame to the starter solenoid.
There are about 5 or 6 sets of pre drilled holes in the inner fender to hold the cable using the plastic push in clips.
The cable to the starter from the battery needs to be about 53 inches long as I recall.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
blkss64
Reg: 07-22-12
04-15-19 08:31 PM - Post#2764309
For the 1964 model year, routing of the cable starts at the battery, then goes down to a clip on the frame across from the fuel pump.
Next it goes between the fuel pump and motor mount to clips that are attached using the oil pan bolts as you described. The clips are available for the pan rail attachment point.
The frame rail clip might be repopped, I just do not know for sure. The cable is approximately 53 inches long. The assembly manual has really poor drawings on some items. Good luck, Jon
Execution time: 0.128 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:07 PM
