Username Post: N 205 Transfer Case        (Topic#356012)
badbob85037
Loc: Arizona
Reg: 03-13-09
04-14-19 06:10 PM - Post#2764227
When I first bought the truck, over 30 years ago I had a problem getting the 205 out of 4 wheel drive. The tires on the truck were 31" but different brand in the front and rear. Once I got a set that all matched I never had another problem except replacing the seals a couple of times. Today I took it out and did a little 4 wheeling. When I got back to pavement I went to take it out of 4 wheel high and it wouldn't disengage. I tried a few time ending up driving a slow ride home in 4 wheel drive. I know nothing last forever but it's a 205. The 35" mud tires I have on the truck now are only 4 or 5 months old and I doughty are the problem, Anyone got a quick fix or is it time to grab me a good shop manual and rebuild it and if so how much am I looking at to do a major rebuild?
Thanks guys.
Senior Chevytalk Moderator
04-15-19 03:57 AM - Post#2764246
    In response to badbob85037
badbob85037,
Check your email. I sent you some NP205 info. Sorry, I can't be much help. I've never taken one apart to see how it works. Let us know if you find the problem.
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
04-28-19 06:41 PM - Post#2765242
This is common. It is bound inside.
Back up and try it, letting it roll to a stop.
Or, back up or drive forward, at 5-10 mph, put (slight) pressure on the 4x4 lever, drive steady, and let off the gas, while in gear, w/the clutch out.
Or, put pressure on the lever and back-up.
Both ways remove the binding. It will pop out w/very little pressure once un-bound.
Execution time: 0.081 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:52 AM
