Username Post: 700R4 frayed cable        (Topic#356008)
Senior Chevytalk Moderator
04-14-19 08:12 AM - Post#2764203
Well, it finally happened. A stock TV setup with a stop cylinder finally frayed the cable. The long end is stuck inside the sleeve. Basically, it unwound itself. It won't pull out any more. It's time to replace the stock TV cable.
Which company makes the best cable? My ZZ4 set up is an RPM Air Gap using an Edelbrock carb. The bracket is modified for height alignment. It bolted down by the rear two left intake bolts. I'll look for pics or take some later.
Does anyone have 700R4 TV aftermarket cable pictures?
Does the pan have to come off to replace the trans hookup? How long is the cable? I don't need another cheap stock replacement. It's an expensive heavily modified 700R4. It needs a cable to give WOT and control TV functions properly. It can barely get of out first gear with such low throttle pull.
04-14-19 08:24 AM - Post#2764204
I haven't had any problems with TCI cables.
No, you don't have to remove the pan. The connection pulls out of the transmission enough to hook the cable to the link.
Link to cable.
04-14-19 09:28 AM - Post#2764205
    In response to acardon
acardon,
The current cable is just like that one. The end cable stop barrel frayed the wire over time. The screw is too sharp.
Great. I don't need to change the oil filter anyway. It has less than 10,000 miles on it. Due to a small leak when parked for long periods of time, fresh oil has been added over the years.
Attachment: 1406linkage.jpg (113.32 KB) 1 View(s)
Frayed 700R4 cable with barrel stop.
Edited by gchemist on 04-14-19 02:33 PM. Reason for edit: No reason given.
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
04-14-19 05:03 PM - Post#2764221
YA MIGHT FIND A CLAMP TYPE,INSTEAD OF THE SCREW SET TYPE.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
04-14-19 05:49 PM - Post#2764225
FWIW, there's typically a lot of TV cable discussions on thirdgen-dot-org (https://www.thirdgen.org/forums/transmissions- drivetrain/). Just a sample....
https://www.thirdgen.org/forums/transmissions- driv...
It is not necessary to drop the pan in order to remove the TV cable from the transmission.
I'd avoid driving it without TV cable control.
You can use the following as a guide:
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
04-15-19 04:04 AM - Post#2764247
    In response to paulo57509
Hey TAT_2,
I had to dig to find a link or part number to that wire clamp. Interesting. European.
They come in different clamping sizes. I'll have to get digital calipers to measure the wire size.
https://www.s3i.co.uk/heavy-duty-wire-rope-r ing-cl...
paulo5709
BADBOW is parked until the cable is replaced. I may try to unbind the cable to drive it to a friends house. It's only a short distance. We may just tow it there. Thanks for all the info. I can use another aftermarket adjustable cable. Using a better cable end clamp will solve the problem from happening again. Thanks for posting pics and links!
rumrumm
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
04-15-19 01:02 PM - Post#2764282
Mine came from Bowtie Overdrives, but Lokar makes a good cable. A lot of street rod guys use Lokar products.
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, FiTECH. Dyno #'s: 450 hp @ 5700, 468 lb. ft. of torque @ 4300.
TAT_2
Reg: 10-29-00
04-15-19 04:08 PM - Post#2764294
FOUND THIS COMPRESSION TYPE ALSO.
https://www.griplocksystems.com/product/30-3816e-v...
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
04-15-19 06:28 PM - Post#2764302
    In response to TAT_2
Use an OEM type cable instead of that cobbled up universal stuff. Get the right cable bracket or modify a cable bracket to get it in the right place fore/aft for the OEM type cable. The cable bracket location does not have to be precision, that's what the adjustment is for.
04-16-19 09:12 AM - Post#2764335
    In response to Rick_L
Rick_L,
I tried a few brackets. Most of them would bend or be too short for a stock cable. A truck 700R4 cable is too short. paulo5709's link has great info. I might be able to use a different 700R4 cable. I need to measure the cable length from bracket to carb. One of the stock cables listed may work. The carb connection does have to be long from it's location, rear two intake bolts.
A: Cable end = 6" = UNKNOWN, V8? Carb?
B: Cable end = 5 3/4" = Crossfire
C: Cable end = 7 3/4" = TBI
D: Cable end = 6 1/2" = TPI
E: Cable end = 5" = V6 ( MPFI ? )
Attachment: carb.jpg (141.07 KB) 0 View(s)
Carb cables with cruise control option.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
04-18-19 07:32 AM - Post#2764464
Funny you should ask ,I just fineshed my 700r4 and am going through this cable fiasco now. I pulled trans and trashed my original cable it got hung up and screwed the end up. Any way I got one of the universal ones like yours but the cable housing is to long for my liking to many curves to the trans ,having a hell of a time finding one that is around the 35" the one I have now is a 39.5 ".I used a Bowtie Overdrive on my 69 C-10 and that is a great setup, but it is now over $200 I cringed at $150 6 yrs. ago.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Texasray
Texasray
Reg: 11-01-16
04-18-19 04:43 PM - Post#2764505
    In response to 69_BOWTIE
Use a cable from a mid '80 F body TPI. They are about 8 inches longer, due to having to reach the throttle body on TPI's.
ATP used to make a great one, we used these back then when replacing junk yard 305's & 350's. The yard always cuts them..???
Anyway the attachment & adjustment will be like the original.
Sam
04-21-19 05:36 AM - Post#2764710
    In response to Texasray
Texasray,
Do you have a GM part number for a TPI cable?
I found these numbers: ATP Y363 {#10079744, 14091865, 25521263
~61" in length. Looks very promising!
I ordered clamps for wire cables from 2.5-5 mm. The three smallest size clamps were ordered. The 2.5 mm clamps look promising to work better on generic TV length cables. The flat clamp will not fray a wire rope cable like a cylinder set screw.
Attachment: clamps.jpg (98.72 KB) 0 View(s)
Cable wire clamps.
Algoma56
Reg: 03-14-05
04-21-19 07:50 AM - Post#2764718
Lots of good info here. I have a 700R4 slated for install behind a F*** small block with Edelbrock carb. Will need to make bracket, etc to install on that manifold.
04-21-19 09:33 AM - Post#2764731
    In response to Algoma56
Algoma56,
The best bracket I found that will not bend/flex for a TV cable is an Edelbrock Throttle Cable Brackets 8036. I had mine cut and extended height wise to align with an RPM Air Gap intake. It bolts to the rear left intake bolts. If you plan to make your own, start with the 8036.
A nice option is a carb adapter if you need one.
http://www.bowtieoverdrives.com/catalog/catalog_in...
Edited by gchemist on 04-21-19 09:36 AM. Reason for edit: No reason given.
Execution time: 0.074 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:30 AM
