Username Post: Stock front bench seat        (Topic#356000)
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
04-12-19 07:58 PM - Post#2764148
56 two door front 3 piece stock bench seat.
If the seat bottom is bolted in to the floor, can you put the 2 seat backs in place?
Meaning with the bench seat bottom installed in the car, can you attach the seat backs?
Or is the steering wheel in the way on the driver side?
I ask because I have taken this 3 piece bench seat in and out more than one too many times by my self,
it is heavy and not much fun.
VC56S 2 door Sedan, 39 Years
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
04-12-19 08:02 PM - Post#2764149
    In response to Bad56Sedan
What is used at the hinge pin on the outer side?
Is it a simple "C" clip? What size is it?
What I took off did not make it through my removal process.
Once again thanks
04-12-19 08:48 PM - Post#2764151
Yes, it's a simple C clip. See page 130:
http://www.eastcoastchevy.com/Cat54PG156to169.pdf
Ace hardware may have them or even Home Depot.
I think you can remove the backs in the car.
Travs55
Travs55
Loc: Houston, Texas
Reg: 03-11-05
04-13-19 09:24 AM - Post#2764165
I have a stock ‘55 sedan and taking the seat backs off is the only way I can get the front seat out by myself. The last time I had the seat out I primed and repainted the mounting rails so it can be done tho I will have to admit I don’t remember how. I live right here in Clear Lake by Ellington Field off of Space Center. Let me know if I can help.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
04-14-19 03:23 PM - Post#2764214
    In response to acardon
thanks for the info Don,
exactly what I need,
could not find those parts at the other 2 places
Trav, thanks for the offer, see ya at academy
Attachment: IMG_1467.JPG (293.64 KB) 12 View(s)
Execution time: 0.084 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:00 PM
