Chevs of the 40s
Username Post: 261 powerglide        (Topic#355993)
Airlifter
Airlifter
Reg: 06-07-15
04-12-19 05:16 AM - Post#2764089
What year 261 will bolt up to my 54 powerglide transmission?
1951 styline deluxe sport coupe w/54 engine & powerglide
Chevs of the 40s
04-12-19 08:12 PM - Post#2764150
    In response to Airlifter
I would think all years would. I don't think the bolt pattern would be different.
Airlifter
Airlifter
Reg: 06-07-15
04-13-19 03:55 AM - Post#2764155
Thanks. Now all I have to do is find one that I can afford.
04-13-19 05:13 PM - Post#2764181
School buses and 2-ton farm trucks had them in the late '50's up thru 1962.
Airlifter
Airlifter
Reg: 06-07-15
04-13-19 06:56 PM - Post#2764185
I have been looking. No luck yet.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
04-14-19 04:36 PM - Post#2764218
Hi Airlifter, If your car is currently Powerglide with a smaller engine then you already have the parts.
You may need to pull the clutch pilot bush out of the 261 crank if it has one, and you will need the adapter flexplate, converter etc from your car.
Should really improve driveability with the extra torque.
Cheers Kiwi
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
04-19-19 12:11 AM - Post#2764533
    In response to Bel Air kiwi
Hi Airlifter, I forgot to mention you need modified engine mounts.
Cheers Kiwi
Chevs of the 40s
Execution time: 0.241 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:00 AM
