Username Post: 58 Chassis repairs        (Topic#355989)
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
04-11-19 12:14 PM - Post#2764060
Picked up a 58 Chassis from a CT member who is somewhat local to me.
Got me some work to do for a bit.
Will be striping off the power steering components, then beat the rust off the chassis and give it a good coat of chassis paint.
Picture of the complete chassis from my security camera.
58 Delray in disaray
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
04-12-19 02:16 AM - Post#2764085
    In response to Techhead
Looks solid, do you have your 58 apart?
Member #2194
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
04-12-19 04:20 AM - Post#2764090
Hey Frank, i thought your chassis was good and you had started assembly. Did you find issues with the other one?
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
Techhead
Techhead
Reg: 10-25-05
04-21-19 05:34 AM - Post#2764713
    In response to Original58
At this point only the front clip is apart and most of the interior.
Jeff
Jeff,
The front front frame has been tweaked, I believe from a collision at some point in its life.
I had to wedge the engine into place using a 5' wrecking bar and a good hour to just get the engine mount bolts into place.
There is an area on the rear of the frame that has a good tear in it from what looks to be from a pull out of a ditch with a big hook.
Techhead
Techhead
Reg: 10-25-05
04-29-19 05:07 AM - Post#2765258
Spent the weekend removing the front suspension and steering.
Need to spend some time with a cutting wheel and grinder on the driverside horn.
In it's past life someone made a mess welding on the power steering bracket.
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
04-29-19 02:38 PM - Post#2765316
Wow that's interesting
Techhead
Techhead
Reg: 10-25-05
05-16-19 06:01 AM - Post#2766532
Got around to cleaning up the welded on rebar. What a mess.
The rebar was added to reinforce the power steering bracket, which I have now taken off.
Just need to weld in a metal plate to replace the steel that was removed.
Edited by Techhead on 05-16-19 06:06 AM. Reason for edit: No reason given.
Techhead
Techhead
Reg: 10-25-05
06-11-19 05:23 AM - Post#2768205
Got the front horn to a spot that I'm happy with.
The rear of the frame needs some persuasion to straighten out. Finally had some good weather to cut the rear off to drag into the garage, easier to bash away while on a bench and using my makeshift anvil.
Bolted in guides, so when I place the rails back on, they will be right where they need to be.
rcr3
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
06-12-19 01:39 AM - Post#2768287
That's some nice, well thought out work there.
Keep up the good work!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
Techhead
Techhead
Reg: 10-25-05
06-17-19 09:18 AM - Post#2768676
    In response to rcr3
ThanX
Got the rear of the chassis straightened out and welded back on. Chassis is upside down for the next fix. (see below)
Now to order me some replacement metal to fix the area where the power steering bracket had been welded on and butchered.
Techhead
Techhead
Reg: 10-25-05
06-19-19 04:25 PM - Post#2768853
The underside of the horn is done. I can now prep the chassis for paint.
Got the chassis upside down and will paint the underside first then flip it over to paint the rest of it.
Techhead
Techhead
Reg: 10-25-05
08-12-19 11:58 AM - Post#2773045
Got my chassis all ready to start putting the suspension on it.
DonSSDD
DonSSDD
Reg: 08-21-01
08-13-19 05:02 AM - Post#2773120
Keep up the good work.
There is a 58 2 door post for sale down here if you need another one.
Member #2194
Techhead
Techhead
Reg: 10-25-05
08-13-19 12:25 PM - Post#2773146
    In response to DonSSDD
Hi Don,
NS is where my Delray came from.
DonSSDD
DonSSDD
Reg: 08-21-01
08-13-19 03:27 PM - Post#2773165
Looks like you'd want to look at this one closely.
Member #2194
Techhead
Techhead
Reg: 10-25-05
10-21-19 08:55 AM - Post#2778416
Took a weeks staycation and it turned out to be very productive.
Lifted the body off the chassis and pulled it out. Got the new chassis in the garage and started to move all the suspension parts over.
Glad I did as the top of the drivers side rear shock mount was toast, with a very poor repair job.
Execution time: 0.153 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:38 PM
