Username Post: One wire powermaster power gen alternator install in 56 Chevy help        (Topic#355960)
flaco_frank
Reg: 03-09-18
04-09-19 01:02 PM - Post#2763914
I recently got a power master power gen alternator part number 82051. I wanted to install it and I’ve heard to just run a direct wire from the battery to alternator,but was wondering if I can still use my original wire that used to go to generator originally? I will not be using the voltage regulator anymore as the new alternator is internally regulated. Any suggestions will be greatly appreciated.-frank
04-09-19 01:35 PM - Post#2763915
    In response to flaco_frank
You could, but it's not a good idea. The original wire is too small for the 90 amp alternator and it runs inside under the dash before it comes back out to the starter. Run a 10 gauge wire directly from the alternator to the battery terminal of the starter. Also run a 14 gauge wire from the alternator to the horn relay to operate the horns.
You can also connect the small brown wire that is now on the generator to the other terminal on the alternator and the "gen" light will work as it always did.
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
04-09-19 08:23 PM - Post#2763938
Be sure and ground the new alt to sheet metal, frame or engine.
I use an 8awg charge wire on my alternator.
Jalapeno
flaco_frank
Reg: 03-09-18
04-10-19 11:15 PM - Post#2764023
    In response to acardon
Thank you very helpful information I will do exactly that and run a wire directly from Margery to alternator
flaco_frank
Reg: 03-09-18
04-10-19 11:16 PM - Post#2764024
    In response to Jalapeno
Good ground got it thanks for feedback all is helpful
flaco_frank
Reg: 03-09-18
04-19-19 06:29 PM - Post#2764606
Thanks for the feedback ran a 6 gauge wire from battery to alternator and a solid 6 gauge ground perfecr
flaco_frank
Reg: 03-09-18
04-19-19 06:31 PM - Post#2764607
Thanks man I ran a 6 gauge wire and a solid 6 gauge ground to the block, got a perfect charge for alternator running solid
Jalapeno
Jalapeno
Reg: 04-30-00
05-04-19 10:01 AM - Post#2765709
Jalapeno
Execution time: 0.126 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:44 PM
