Username Post: WTB - '53-'54 Corvette 235 Exh. Manifold        (Topic#355952)
64K10
64K10
Loc: Cali
Reg: 06-25-04
04-08-19 06:59 PM - Post#2763850
Looking for a '53-'54 Corvette 235 exhaust manifold.
Somebody's got to have one they're never going to use. I promise to put it to good use!
64K10
Edited by 64K10 on 04-08-19 06:59 PM. Reason for edit: No reason given.
64K10
64K10
Loc: Cali
Reg: 06-25-04
04-30-19 12:36 PM - Post#2765396
    In response to 64K10
Found one over on VCCA.
Thanks Doug.
64K10
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
05-01-19 10:51 PM - Post#2765515
Doug does the stock Vett have any dividers inside or other --tricks-- that make it better than just adding the second outlet to a standard single outlet? Most Vett ones were 1,500 plus last time I looked for my 57 235.
64K10
64K10
Loc: Cali
Reg: 06-25-04
05-02-19 12:45 PM - Post#2765567
    In response to Mel Foye
Mel,
(Don't know if Doug checks in here.)
Yes, there is a difference. On Vette manifold cylinders 1, 2, and 3 feed into what would be the center of a regular 235 manifold (where it contains the heat riser flap and bolts up to the bottom of the intake manifold). Cylinders 4,5,and 6 feed into their own down tube. There is no opening between these two sections.
As for prices, in the past 6 months or so I've seen them go for $800 to $1100, so $1500 seems a bit high. If you were doing an NCRS car and absolutely needed the manifold and don't want to wait for another better snag it. Although, I would still ask the individual to come down on the price.
Shipping, UPS ground across county will be about $60.00 and take about a week.
64K10
Edited by 64K10 on 05-02-19 12:47 PM. Reason for edit: No reason given.
64K10
64K10
Loc: Cali
Reg: 06-25-04
05-02-19 03:12 PM - Post#2765579
'53 - '54 Corvette exhaust looks like this.
64K10
Edited by 64K10 on 05-02-19 03:31 PM. Reason for edit: No reason given.
64K10
64K10
Loc: Cali
Reg: 06-25-04
05-02-19 03:26 PM - Post#2765580
Currently being test fitted under a Thickstun intake on a "848" head.
Rochester BC carbs are not bolted down yet. Studs coming up from the bottom of the exhaust manifold are about 5/16" too long as they won't allow the accelerator linkage rod to be installed on the back of the intake.
Well this is kinda a Corvette related thread, although this is going in a '50, 1/2T Panel
64K10
Edited by 64K10 on 05-02-19 03:29 PM. Reason for edit: No reason given.
Mel Foye
Mel Foye
Reg: 09-29-00
05-02-19 11:19 PM - Post#2765601
Thanks for the info and pics as I learned a bunch. I even did a search on Thickstun as I don't think I have ever even heard of them. Owner died in 1946!!!
Take care.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
10-13-19 11:50 AM - Post#2777791
There's almost always one of these exhaust manifolds for sale on that auction site we all know and love; same with intake manifolds and carburetors. It's just a matter of, "how much do you want to spend?". I am Butch/56sedandelivery.
Execution time: 0.089 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:14 PM
