Username Post: Hood question        (Topic#355928)
okayletsrock
Reg: 05-03-16
04-07-19 01:04 PM - Post#2763786
We took the hood apart on my 67 Impala. Separating it into the inner hood brace and the outer skin for repairs. In taking it apart there were quite a few areas where it rusted where it looks like some sort of foam circles were. These are between the inner brace and the outer skin.
Does anyone know what these are? Are they just mounts? Are they rubber? foam? I'm just not sure what to search for to look up what is to replace them since they are just dust at this point.
PatwithaRat
PatwithaRat
Loc: Bardstown, Ky. USA
Reg: 02-22-02
04-08-19 05:03 AM - Post#2763804
    In response to okayletsrock
IIRC, on my '69 there were random gobs of some kind of adhesive oozed out from between the hood and bracing. I figured it was there to prevent the hood from rippling, like you sometimes see happening on Nascar race cars.
Voted most likely to end up working at a car wash.
okayletsrock
Reg: 05-03-16
04-08-19 06:43 AM - Post#2763809
    In response to PatwithaRat
Ah okay. I hadn't thought about them being an adhesive. But that makes sense.
okayletsrock
Reg: 05-03-16
04-08-19 08:53 AM - Post#2763815
Thanks I'm going with this
https://www.autobodytoolmart.com/3m-duramix-nvh-da...
"15th Year" Platinum Supporting Member & Moderator
04-12-19 11:03 AM - Post#2764117
Some guys have used "expanding" foam adhesive.
Don't do that!
If you do, you'll be buying a new hood!
That adhesive keeps the upper and lower halves from contacting each other.
Execution time: 0.131 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:04 PM
