Username Post: Fuel tank sender question....        (Topic#355899)
MoboMac
MoboMac
Reg: 08-22-11
04-04-19 01:44 PM - Post#2763638
Is a sealant needed on the gasket between tank and sender?
This is the flat paper style...not o-ring...
formerly Cameo Coral.....now appearing as MoboMac
Franks 59....
http://www.youtube.com/watch?v=UokRArv4eSo
This car and vid is ART!
Turn it up & go full screen....
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
04-04-19 03:09 PM - Post#2763644
    In response to MoboMac
I purchased my gasket, cork, from Chevi Shop Custom Casting, gcoleman@frontier.com The original hex head screws had a small rubber o- rings and I picked up some at a local hydraulic shop. I used Seal All on the gasket and Loctite thread sealer on the screws and it hasn't leaked any so far. This is what I did but think that it would work with the paper gasket Hope this helps, Lamar
Attachment: FullSizeRender_-_Copy__2_.jpg (45.48 KB) 16 View(s)
Attachment: FullSizeRender_-_Copy.jpg (731.07 KB) 12 View(s)
MoboMac
MoboMac
Reg: 08-22-11
04-04-19 04:20 PM - Post#2763653
    In response to PLS
Thanks for your reply....
I was thinking Seal all.....but thought it might be overkill....if I ever had to take it apart again....
That stuff is pretty amazing...
Franks 59....
TYTILIDIE
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
04-15-19 05:26 PM - Post#2764300
I used RTV (The Right Stuff) on my EFI tank and a lot of it ended up in the tank.
Me
Execution time: 0.142 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:25 AM
