Username Post: Fluid for valve leak test?        (Topic#355884)
ShortyLaVen
Loc: Minneapolis, MN, and Phoe...
Reg: 01-23-18
04-02-19 09:33 PM - Post#2763538
What fluid do you typically use to test how well your valves are sealing? I was thinking something the diethyl ether would be good because of its very low surface tension, but I've also heard of people using acetone for the same reason. I have both in the shop, as well as mineral spirits, gasoline, turpentine, lacquer thinner, etc.
04-03-19 01:18 PM - Post#2763586
    In response to ShortyLaVen
Use the mineral spirits, as it's less of a danger than the rest.
454cid
Loc: West Michigan
Reg: 02-18-12
04-03-19 11:09 PM - Post#2763609
    In response to Rick_L
Couldn't rubbing alcohol be used?
99 K3500 RCLB
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
04-04-19 05:06 AM - Post#2763614
    In response to 454cid
rubbing alcohol with food dye works just fine
Edited by grumpyvette on 04-04-19 02:17 PM. Reason for edit: No reason given.
04-04-19 10:47 AM - Post#2763626
    In response to grumpyvette
Rubbing alcohol from the drug store is actually what I use. Also what I use for cc'ing combustion chambers and ports. A pint bottle lasts a long time.
I picked the mineral spirits from his list.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
04-05-19 09:36 AM - Post#2763694
i have used kerosene
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
ShortyLaVen
Reg: 01-23-18
04-27-19 10:39 AM - Post#2765142
Thanks all for the replies, I ended up using alcohol/water mix on the first round (had to mix because I didn't have much left, it worked out to be about 60% alcohol), and then used mineral spirits for the second test after lapping and cleaning.
Execution time: 0.083 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:52 AM
