Username Post: Sudden backfireing?        (Topic#355870)
HotRodg57
HotRodg57
Loc: San Marcos CA USA
Reg: 06-04-01
04-01-19 07:11 PM - Post#2763450
For some reason for the last 2 weeks my truck has started to backfire whenever I get off the throttle, or decelerate. (52 1/2 ton 235-6 4spd)It runs great, and has been for a couple of years. It never did this before. Sounds kinda like twice pipes. My choke and throttle cables are all the way in. I haven't changed anything.
And it's getting irrigating. Any ideas?
Rodger
Check out my Car Pics
04-02-19 08:08 AM - Post#2763482
    In response to HotRodg57
A vacuum leak can cause that, it's thru the exhaust or intake?
HotRodg57
HotRodg57
Reg: 06-04-01
04-02-19 04:04 PM - Post#2763511
Thanks, from the exhaust. I'll try checking with some carb spray for intake leaks.
Rodger
HotRodg57
HotRodg57
Reg: 06-04-01
04-04-19 04:48 PM - Post#2763655
Looks like I need a new manifold gasket. It's leaking big time. Thanks for the tip.
Rodger
HotRodg57
HotRodg57
Reg: 06-04-01
04-10-19 11:13 AM - Post#2763965
*Update- * Turns out my intake manifold bolts had come loose. The gasket "slipped" out of place a little. I tapped the gasket back into place and retightened the bolts. Purrs like a kitten again.
Rodger
04-10-19 07:42 PM - Post#2764017
It’s always nice when a fix is easy and free.
1957 Cameo Carrier
Bel Air kiwi
Deceased Member RIP
Bel Air kiwi
Reg: 04-24-14
04-17-19 06:07 PM - Post#2764432
Hi HotRodg57, The intake manifold gasket should not drop down when the manifold comes loose.
As built these engines had a short tubular sleeve that went in the intake ports and the gasket fitted over them so it cant drop.
This isn't just an install issue. Chevy put them there for exactly this reason. They support the gasket and align the manifold.
Have a look at a manual as there is a bit more to the proper sealing of the intake/exhaust combo than just tight.
A number of alignments matter.
Cheers Kiwi
Edited by Bel Air kiwi on 04-17-19 06:08 PM. Reason for edit: No reason given.
HotRodg57
HotRodg57
Reg: 06-04-01
04-26-19 06:16 PM - Post#2765116
    In response to Bel Air kiwi
Actually, it kinda slipped up. It was sitting about 1/4' above the manifold. I barely tapped it and it fell into place. Tightened up, and bingo
Rodger
Execution time: 0.088 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:56 AM
