Username Post: 1954 Truck        (Topic#355853)
jprenat
Reg: 04-01-19
04-01-19 12:31 PM - Post#2763407
Hey all, need a little guidance. I just purchased a 1954 3600. I am looking to makes some upgrades and wanted a little help. I have heard but not 100% sure that a Corvette C4 rear end, suspension, and spindles will work on a 54. Is this correct?
Bel Air kiwi
Deceased Member RIP
Bel Air kiwi
Reg: 04-24-14
04-18-19 07:39 PM - Post#2764520
    In response to jprenat
Hi JPRenat, Welcome. If I am correct then the 3600 is the longer wheelbase variant of either 3/4 or 1/ton?
In truth, you can put any suspension and driveline in anything but how much it costs and how well it works is the real question.
If your original frame is solid then there is a raft of aftermarket fronts and rear conversions available including complete frames like an Art Morrison.
If you can give us a better idea of what your needs and wishes are and how much you think you should spend then we can give you focussed advice.
What condition is your original frame in?
Cheers Kiwi
Edited by Bel Air kiwi on 04-18-19 07:39 PM. Reason for edit: No reason given.
Execution time: 0.085 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:19 AM
