Username Post: Scissor lift        (Topic#355817)
56KIE
56KIE
Loc: Winnipeg Manitoba Canada
Reg: 12-13-18
03-29-19 09:04 AM - Post#2763158
I don't have enough height in my garage for a 2 or 4 post lift,only an 8' ceiling.
Found this at local Costco store yesterday, a hydraulic scissor lift, 21" lift 7000Lb capacity.
For $1,449.99 Canadian, also on line for $50 more.
Also seen a 5000 LB one on Costco.com for $999.00US
I figure with a little ingenuity I could make an extra stand to put it on & get my Nomad to the ceiling. After lifting & putting on jack stands then using the stands to lift again.
Not as nice as a lift, but better than nothing.
Attachment: aaa.jpg (108.26 KB) 4 View(s)
J C
J C
Loc: Orange Co. Calif
Reg: 04-17-04
03-31-19 03:17 PM - Post#2763337
    In response to 56KIE
Boy. I don't know. Most smaller scissor lifts that I have seen do not have a large (wide) foot print. Also the ones that I have been on were not real solid the higher up you went. So to put a car that is what 6-7 ft wide 15ft long might be a little nerve racking if it were my car. You might try to find a junker car and see if it works. IMO I'm sorry I did not look at the picture. I was referring to the type contractors use. This type will probably work just fine.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
Edited by J C on 03-31-19 03:35 PM. Reason for edit: No reason given.
KaelFarmer
KaelFarmer
Loc: Eau Claire, WI
03-31-19 03:32 PM - Post#2763338
    In response to J C
I am considering one of these for use in my garage with low ceiling height. I had considered a low level scissors lift when I found out about this.
www.maxjaxusa.com
It is a 2 post lift designed for low ceilings
Kael
2blu52
2blu52
Reg: 03-12-02
04-01-19 05:30 AM - Post#2763378
    In response to KaelFarmer
If I had known about these I would probably have kept the 52 as it would sill have been possible for me to work under the car.
THOMAS JEFFERSON
56KIE
56KIE
Reg: 12-13-18
04-03-19 09:57 AM - Post#2763574
I was looking at the MaxJax lift, but i found one up here in Canada, virtually the same.
It needs 7'5" max height & will allow 45" under the vehicle (6,000Lbs), also portable like the MaxJax.
although it is on sale now till June for $1,900 Canadian & will only cost me $240 to have it shipped. It is a Mondial GP-6 model, found it on Kijiji in Winnipeg under 2 post lift.
At least it will allow me to lift the body off the frame. I will vault my ceiling to 9' 6" to allow me to use the full 45" of lift.
just checked the specs & this is actually a MaxJax just re-branded is all.
Edited by 56KIE on 04-03-19 12:47 PM. Reason for edit: No reason given.
Execution time: 0.05 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:51 AM
