Username Post: Scissor lift        (Topic#355817)
56KIE
56KIE
Loc: Winnipeg Manitoba Canada
Reg: 12-13-18
03-29-19 08:04 AM - Post#2763158
I don't have enough height in my garage for a 2 or 4 post lift,only an 8' ceiling.
Found this at local Costco store yesterday, a hydraulic scissor lift, 21" lift 7000Lb capacity.
For $1,449.99 Canadian, also on line for $50 more.
Also seen a 5000 LB one on Costco.com for $999.00US
I figure with a little ingenuity I could make an extra stand to put it on & get my Nomad to the ceiling. After lifting & putting on jack stands then using the stands to lift again.
Not as nice as a lift, but better than nothing.
Attachment: aaa.jpg (108.26 KB) 18 View(s)
J C
Loc: Orange Co. Calif
Reg: 04-17-04
03-31-19 02:17 PM - Post#2763337
    In response to 56KIE
Boy. I don't know. Most smaller scissor lifts that I have seen do not have a large (wide) foot print. Also the ones that I have been on were not real solid the higher up you went. So to put a car that is what 6-7 ft wide 15ft long might be a little nerve racking if it were my car. You might try to find a junker car and see if it works. IMO I'm sorry I did not look at the picture. I was referring to the type contractors use. This type will probably work just fine.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
Edited by J C on 03-31-19 02:35 PM. Reason for edit: No reason given.
KaelFarmer
KaelFarmer
Loc: Eau Claire, WI
03-31-19 02:32 PM - Post#2763338
    In response to J C
I am considering one of these for use in my garage with low ceiling height. I had considered a low level scissors lift when I found out about this.
www.maxjaxusa.com
It is a 2 post lift designed for low ceilings
Kael
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
04-01-19 04:30 AM - Post#2763378
    In response to KaelFarmer
If I had known about these I would probably have kept the 52 as it would sill have been possible for me to work under the car.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
56KIE
56KIE
Reg: 12-13-18
04-03-19 08:57 AM - Post#2763574
I was looking at the MaxJax lift, but i found one up here in Canada, virtually the same.
It needs 7'5" max height & will allow 45" under the vehicle (6,000Lbs), also portable like the MaxJax.
although it is on sale now till June for $1,900 Canadian & will only cost me $240 to have it shipped. It is a Mondial GP-6 model, found it on Kijiji in Winnipeg under 2 post lift.
At least it will allow me to lift the body off the frame. I will vault my ceiling to 9' 6" to allow me to use the full 45" of lift.
just checked the specs & this is actually a MaxJax just re-branded is all.
Edited by 56KIE on 04-03-19 11:47 AM. Reason for edit: No reason given.
TAT_2
Site Ambassador - Member #26 - "19th Year" Silver Supporting Member
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
05-01-19 04:53 AM - Post#2765461
SEEN THIS IN A NAPA FLYER IN WORK.LOOKS INTERESTING.
WISH I HAD A GARAGE TO PUT IT IN.
https://jmcautomotiveequi pment.com/esco-92055-mini...
09 PONTIAC- VIBE
08 PONTIAC- G6
93 VETTE - 40TH ANIV- RUBY RED- LT1/6-SPD/RAG TOP
QUOTE FROM HELEN
56KIE
56KIE
Reg: 12-13-18
05-03-19 09:50 AM - Post#2765631
    In response to TAT_2
looks good, although i want to lift higher than 24"
06-17-19 01:04 PM - Post#2768700
Is this the same one?
https://www.bendpak.com/car-lifts/portable-ca r-lif...
BL-7000EXT
7,000-lb. Capacity / 21" Maximum Rise / 3.5" Lowered Height / 76" Frame Length
I like it!!
'08 GMC Acadia 3.6L SLE
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
06-17-19 05:51 PM - Post#2768721
https://www.ezcarlift.com/
https://www.kwik-lift.com/
several guys I know own these and have nothing but good reviews
Edited by grumpyvette on 06-18-19 06:00 AM. Reason for edit: No reason given.
06-18-19 05:22 AM - Post#2768742
    In response to grumpyvette
Take my $$$$! Barely enough to raise my '83 truck. Can't raise the extended cab truck. I need one that can lift 7000 lbs to be safe.
56KIE
56KIE
Reg: 12-13-18
08-02-19 10:44 AM - Post#2772245
56KIE
56KIE
Reg: 12-13-18
08-02-19 10:53 AM - Post#2772246
these are all good & very similar, just depends on what you are doing & the height of the ceiling.
I still want one to go high enough to stand under the car, found a few i liked but still looking.
if i vault the ceiling, most will work. Just seems expensive for one car build, (although i have spent more for less of a job before).
Getting new floors in the Nomad now & have a spare frame to set it on while i do the original frame. so may not need a lift anymore, they even have a rotisserie for me to use for free. from the people i bought the Nomad from, they do sheet metal work for resto mods.
Execution time: 1.153 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:03 AM
