Username Post: Exhaust smell in car        (Topic#355792)
apix17
Loc: San Francisco Area
Reg: 12-22-07
03-27-19 12:52 PM - Post#2763019
My 55 Belair 2dr Hdtp with sb has an exhaust smell in the passenger compartment says me and everyone that rides in it. I found several small leaks on engine like exhaust manifold to head and at the exhaust manifold donuts.Repaired those leaks and all holes in firewall, no help. The dual exhaust system, pipes and mufflers are solid. I am starting to think exhaust gases are entering through the trunk seal which is not snug especially near the tailpipe. The tailpipes extend about 2 inches from bumper. Also car has pcv so not blowby we are smelling. I was wondering if anyone has had similar problems. Thanks in advance for your comments.
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
03-27-19 03:13 PM - Post#2763024
    In response to apix17
You might try a set of turn down exhaust tips to direct the exhaust downward andsee if it makes any difference.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
03-28-19 04:51 AM - Post#2763054
Are your floorboards full of holes?
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
apix17
Reg: 12-22-07
03-28-19 09:46 AM - Post#2763071
    In response to kingkreeton
Car is very solid, corrosion free, no holes anywhere. I like the thought of trying the exhaust extensions facing down. Worth a try thanks wagon man.
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
03-30-19 06:54 AM - Post#2763258
The tips may help and end the problem. Yah you knew a --but-- was coming. When you are at speed there will be a large low pressure area at the back bottom area of the trunk. If seals are bad may still enter the trunk. Mel
pauldian
Loc: seligman,arizona
Reg: 05-14-09
03-31-19 11:03 AM - Post#2763321
    In response to Mel Foye
If it was my car I would start the car put on a pair of gloves and check around the exhaust manifolds.
Might want to crawl under the car and feel for holes in the pipes themselves. One persons opinion !
Execution time: 0.057 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:19 AM
