Username Post: Heater core by pass        (Topic#355782)
03-26-19 01:38 PM - Post#2762952
Anyone have their heater core by passed? I'm thinking of by passing mine. I don't need the heater heat very often. The cab sure does get HOT in Texas. However, I think the flap is partially open too. The lever won't go all the way left. A/C would work better too.
Anyone have a picture? There are several ways to by pass the core.
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
03-26-19 07:00 PM - Post#2762961
I just pulled the hoses off the heater core,then coupled them together with a nipple. Left the hoses connected to the water pump Worked for me
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
03-27-19 04:17 AM - Post#2762981
    In response to Lead sled
Yup, that works. Did the same bypass on my '96 Jimmy once. I towed an empty enclosed trailer several hundred miles to help a friend move. A day before coming back, the core leaked into the cab. Luckily, I had my trusty old metal Craftsman tool box. In it, I had a small pipe that fit both hoses perfectly. I connected them together and drove home with it bypassed.
How did you cover the core connections?
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
03-27-19 11:05 AM - Post#2763009
Good ol duct tape...What else?
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
04-01-19 03:43 PM - Post#2763425
Just put a ball valve in the inlet hose between the heater core and the intake manifold to shut off the hot water when you don't need heat. I have done that on practically every vehicle I have owned that did not have an actual heater shut-off valve. When you need heat to defog the windows its only a matter of popping the hood and twisting open the valve.
Edited by 1983G20Van on 04-01-19 03:43 PM. Reason for edit: No reason given.
04-02-19 04:31 AM - Post#2763467
    In response to 1983G20Van
On my next run to HD, I'll look for a hot water ball valve.
Maybe two. Anyone remember the ID for hoses?
Needing defrost this morning, it took a long time for it to defrost a little frost. I need to check the flap cables. Something is not working right. Plus, I hear a vac leak behind the controls. Right now, BADBOW is my daily driver while I wait on an ECM for our Ram truck.
454cid
Loc: West Michigan
Reg: 02-18-12
04-10-19 12:19 PM - Post#2763968
On my truck, the supply hose is 3/4" (1/2" pipe thread) and the return hose is 5/8". I have a GMT-400, but I kind of assume that was standard GM, so your Squarebody may be the same. I don't think you'll find 5/8" hose barbs in the plumbing department.
I've recently being thinking about doing this very thing again. I've got the valve, but wasn't able to mount it where I wanted and then sort of lost interested in doing it. I really don't need 200F coolant circulating into the cab, during the summer, even if I'm not pushing air through it.
99 K3500 RCLB
04-10-19 03:32 PM - Post#2763987
    In response to 454cid
Thanks for posting sizes. I'm sure they are same size. The return is larger to prevent pressure build up. I remember seeing a four connection setup available for recreational vehicles. It connected hoses on both sides. By closing the valves, the water returned without going through the core. I have searched for pictures and have not found it again. Someone posted. Maybe a history search here might bring it up.
454cid
Loc: West Michigan
Reg: 02-18-12
04-12-19 05:48 AM - Post#2764093
On my truck it's the supply hose that's larger... definitely 3/4" from the manifold, and 5/8th's to the radiator. The quick-misconnect on the intake manifold would have been pretty restrictive, Though. I just have a brass barb, now.
Rockauto has two listed for my truck, but very few trucks (GMT-400) actually used them.
https://www.rockauto.com/en/moreinfo.php?pk=815526...
They're vacuum operated, but you can probably find a cable operated version if you dig... if you need that. GMT-400's have electric HVAC controls so the trucks/SUVs that used the valve also had a electric to vacuum conversion thing in there, too.
99 K3500 RCLB
04-12-19 06:43 AM - Post#2764096
Thanks 454cid.
I did find that part number. I also found another, AC Delco 15-5675. I ordered it locally. Once I receive it, I'll post a picture.
I did find the RV bypass valve. $400?? No way!
VanLife
Reg: 03-20-18
04-12-19 02:33 PM - Post#2764132
I believe its partially open on purpose. its part of the condensation removal system when running internal air?
when asking Questions its related to van I own: 1987 GMC 3/4 ton G2500 vandura, V6, No AC, standard length. 3speed trans(no overdrive).
VanLife
Reg: 03-20-18
04-12-19 02:41 PM - Post#2764134
I don't think its a good idea to block off the flow to the heater core using a ball valve. you could inadvertently also block the cooling for a portion of the engine block leading to over heating along the area where that coolant is flowing that goes to the heater core. The heater core in a way acts as a secondary radiator as well.
454cid
Loc: West Michigan
Reg: 02-18-12
04-13-19 01:07 AM - Post#2764154
    In response to VanLife
We already have thermostat bypasses. I believe the heater circuit fills that function on some engines, but not ours. Our radiators should be plenty big enough to handle the cooling of the engine... just think how little cooling the heater core contributes during the hottest part of the year, when the air is bypassing the heater core.
99 K3500 RCLB
75gmck25
Loc: Alexandria, VA
Reg: 12-25-07
04-14-19 06:37 AM - Post#2764199
Another simple check of the heater.
- Remove the glove box door
- Take off the lower panel on the heater box (couple of screws on the bottom, maybe one on the top)
- Clean out all the junk that is keeping the heater blend door from going to full cold. Also check the adjustment of the blend door cable on top of the box.
You may still get some heat out of the box, but it will be a lot better when that door seals completely.
Bruce
04-14-19 02:08 PM - Post#2764210
    In response to 75gmck25
Ok, AC Delco 15-5675 will not work. Though it has four connections and bypass, it will not work. I don't even know how it works. It seems to be temperature controlled for bypass. I'm going to look at the FOUR SEASONS 74781 or Ranger vac bypass valve. Since the Edelbrock 1406 has full vac port available, I can use it as a vac source to bypass the heater core.
The heater can help cool an engine. However, I don't feel like roasting myself. I'm not worried about cooling. A 454 core radiator and dual LS fans keep temps at an ideal aluminum head operating temperature of 195. Fans turn on at 205 degrees and off at 190. Soon, I'll install an auxiliary fan for A/C use. Since it will be front mounted, engine over cooling should not happen.
Edited by gchemist on 04-14-19 02:12 PM. Reason for edit: No reason given.
454cid
Loc: West Michigan
Reg: 02-18-12
04-16-19 02:13 PM - Post#2764350
Yeah, I started looking that, and I was confused too. I started doing some reading on it, and I think it's may be to provide a thermostat bypass in the case of the heater core plugging.
This is something my uncle taught me many years ago. We had my grandmothers car, driving to Wisconsin, and it started running too hot, so we shut the AC off, turned on the heater, and opened the windows. It was a fullsize Buick with a 4.1L V6.
99 K3500 RCLB
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
04-16-19 02:21 PM - Post#2764351
Many years ago we were always told when overheating, turn on heater. This was before dual electric fan setup. Now I think the solution is to turn on AC so both fans are working.
1974 Cheyenne 10 LWB 350/TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
454cid
Loc: West Michigan
Reg: 02-18-12
04-18-19 04:47 AM - Post#2764448
    In response to Liberty Valance
Running the AC is going to make the engine work harder, generating more heat, plus the heat removed from the interior of the vehicle has to be dissipated. I would hope manufacturers would have sense enough to have the PCM turn on both fans when an engine is running hot.
99 K3500 RCLB
04-21-19 06:24 AM - Post#2764712
Ordered the Four Seasons 74781 valve. It's vacuum operated. A mounting bracket or hole will added to the right wheel well cover. I can bypass the vac operation by using a zip tie. Using a vac operation set up, allows the valve to open up and help engine cool down after turning it off. I'll do a mock up and post pictures.
Once I order a TPI TV cable to replaced the frayed cable, BADBOW will go a friend's house for work.
Ya'll can follow the 700R4 frayed TV cable post here: https://www.chevytalk.org/fusionbb/showtopic.php?t...
Parts on the list for installation: heater by pass valve, new TV cable, A/C front condenser electric fan, reinstall grill bow tie emblem, fit right header collector leak, new window tint, and check the A/C-heater core box for operation.
Mad Professor
Reg: 12-30-08
04-21-19 06:24 PM - Post#2764776
I used a ball valve on mine, but it is a 292 w/4 core radiator.
If you still want a flow a 3-port ball valve on the inlet, and a simple t-fitting/conector on the outlet, might be the ticket.
3-way ball valves
They make electrically actuated ones but I'm not sure if 12V? That is you could wire a switch to the dash.
62 Willys wagon
67 CJ5 Buick V6 w/OD
89 S10 baja package
454cid
Loc: West Michigan
Reg: 02-18-12
04-21-19 10:46 PM - Post#2764791
But you won't have circulation, when it's off... unless you're using an electric pump on a timer?
I need to do that too... actually just install the used grille that I have, that already has the emblem.
99 K3500 RCLB
04-22-19 04:46 AM - Post#2764799
When the truck is off, the vac loss will open the bypass valve. Water in the heater core will be cooler than engine/radiator water. The core water will pull heat out of the cooling system. I don't want standing still inside the core either.
Since I have remove the grill to install the auxiliary cooling fan, it's a great time to install the emblem. I have not found a replacement emblem with studs for an 88-91 grill. I had it glued on. I'm lucky it lasted a few years without falling. This time, I may use vinyl to cover the bow tie. Vinyl is easy to replace every few years.
454cid
Loc: West Michigan
Reg: 02-18-12
05-04-19 05:38 AM - Post#2765691
Did this ever get finished?
99 K3500 RCLB
05-05-19 04:43 AM - Post#2765749
Not yet. I have the valve ready for installation. I'm still looking for a TV cable solution. My setup is unique. With help from the Performance Section, I think we have a solution. A TPI TV cable should be close enough to correct length for use. I'll post valve and install pictures.
07-04-19 06:11 PM - Post#2769952
Liberty Valance has provided a nice picture of a mounted auxiliary fan. I'm adding one to help with a/c cooling. If it's not enough, the trinary switch will also activate the dual LS cooling fans. I'll have to test the system. Hopefully the auxiliary fan is enough. Mine will have to mount on the driver side. The passenger side has a large external transmission oil cooler. I'll post pictures when I do the project. It will be at least 2-4 weeks out.
Attachment: fan.jpg (299.5 KB) 9 View(s)
Photo credit: Liberty Valance.
07-18-19 06:44 PM - Post#2771019
Here is a pic of a heater core bypass valve. It's a Ranger part number. Completely closed, a little water may still flow through. For now, I plan to tie the valve up for bypass. Later, I'll experiment with vacuum control. The carb has a full vacuum port that I can use. No danger in water getting into the vacuum part. If this valve does not work out after testing, I'll probably switch to ball valves.
Attachment: bypassvalve.jpg (45.21 KB) 6 View(s)
Heater core bypass valve.
bronco777
bronco777
Loc: Central Valley, CA
Reg: 04-05-15
08-20-19 10:20 AM - Post#2773675
The simplest way to bypass the heater core is to connect the inlet and outlet hoses using a heater hose connector. Dorman makes one that is 3/4” x 5/8” and is part #47080. I do this in the summer on my ‘89 Suburban so the A/C doesn’t have to cool any warm air coming off the core. In the winter I reconnect the hoses to the heater core for heat. Cap the heater core tubes with correct size rubber caps (Dorman makes rubber vacuum caps that work), or just use painter’s tape. This is also a short-term solution to a leaking heater core that is dripping coolant into the truck cab.
1989 Suburban 3/4 ton, 4x4, 5.7L TBI stock
1972 Ford Bronco
Execution time: 0.161 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:46 AM
