Username Post: Manual shift steering column spring 65 Impala        (Topic#355770)
Bill 356
Loc: Ohio
Reg: 03-25-19
03-25-19 01:32 PM - Post#2762863
I disassembled my manual shift steering column for paint . The one item I did not make a note of was the location of the column spring. I think it goes down between the lower bearing and a clamp with a bolt through it.Not up below the steering wheel .Is this the correct? Thanks
Bill 356
Loc: Ohio
Reg: 03-25-19
08-07-19 11:53 AM - Post#2772629
    In response to Bill 356
Still need a little help assembling the spring in my column.
66cayne
66cayne
Reg: 08-06-08
08-07-19 12:49 PM - Post#2772631
Yes that's were it goes, at the bottom above the bearing. Did you lubricate the bearing packing? Be careful with that lower bearing, it's easy for the roller bearings to fall out
Gaspains
Gaspains
Loc: Mankato, MN
Reg: 11-23-09
08-07-19 01:17 PM - Post#2772637
Assuming by manual shift you mean 4-speed, it might be helpful to look at the exploded diagram on page "Steering 9-7" in the 65 Chassis Service Manual in the Reference Section on the home page.
Kevin
1965 Impala SS Coupe
Regal Red with Black Interior
L74 327
M-20
3.31 Open, 12 bolt
65-66 FSCC #512
NIA #2832
Bill 356
Loc: Ohio
Reg: 03-25-19
08-07-19 02:11 PM - Post#2772641
    In response to 66cayne
Thanks that will be a good start.
Bill 356
Loc: Ohio
Reg: 03-25-19
08-07-19 03:04 PM - Post#2772643
Sorry do you mean above the lower bearing towards the firewall inside the tube out of sight?
66cayne
66cayne
Reg: 08-06-08
08-07-19 05:26 PM - Post#2772652
No. It is installed on the engine side of the bearing. Its in plain sight when installed. I will send a pic.
Edited by 66cayne on 08-07-19 05:34 PM. Reason for edit: No reason given.
66cayne
66cayne
Reg: 08-06-08
08-07-19 05:42 PM - Post#2772653
no dice, the picture file is 5.30mb and we can only send up to 4.77 pic files. Its just a basic cellphone pic, too bad. If you send an email address in pm I can send to you.
62BillT
"19th Year" Silver Supporting Member
62BillT
Loc: Moneta, VA
Reg: 09-24-01
08-07-19 07:32 PM - Post#2772664
I told you Bill, lol.
(We were talking on the phone earlier today)
Member:
-National Impala Association
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
08-08-19 06:54 AM - Post#2772686
    In response to 62BillT
A little tidbit, if you save a jpeg pic to a separate file on your computer its file size will go down. For instance the 5.30mb may reduce to around 4.00 and it doesn't appear to hurt the quality of the pic.
66cayne
66cayne
Reg: 08-06-08
08-08-19 07:24 AM - Post#2772687
    In response to aghaga
Unfortunately not in this case. Cellphone jpeg is 5.31. Saved as a file on my PC was 5.30. So it is too big. I am a newby Silver member so I've just begun to upload photos. Maybe its time to consider upping the limit on file size? I know that creates extra cost for the site but if users with larger file sizes are willing to foot the bill perhaps it can be considered.
Bill 356
Loc: Ohio
Reg: 03-25-19
08-16-19 09:51 AM - Post#2773305
Problem solved . Thanks to all for your help.
Bill
Execution time: 0.077 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:49 AM
