scottscheffer
Loc: los angeles
Reg: 01-28-18
03-24-19 08:14 PM - Post#2762807
Hi all,
I have a short block gen 1 350 that I am getting ready to put together for my 67 El Camino. I had big plans, but now I'm starting to think maybe I want as little modification as possible. If I use Vortec heads using the stock cam, does that present any problems? I'm feeling like I don't want to deal with shortening valve stems or valve guides, or using different springs or whatever. I have to get heads anyway, so using Vortecs with a Vortec carb intake seems like a no brainer. Any thoughts? I'm not completely ruling out a mild cam, and headers of course, but I'm feeling kind of lazy these days and just looking forward to getting it fired up.
Scott
Edited by scottscheffer on 03-24-19 08:15 PM. Reason for edit: No reason given.
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
04-04-19 08:16 AM - Post#2763624
In response to scottscheffer
aftermarket vortec heads like these, linked allow a .520 valve lift and are no problem with a mild performance cam , something like a crane 114132 wakes up a mild 350 noticeably and it works with all the stock converters gears fuel pumps etc
https://www.summitracing.com/parts/crn-114132
https://www.summitracing.com/parts/nal-19331470
IF YOU CAN , YOU NEED BETTER TIRES AND YOUR SUSPENSION NEEDS MORE WORK!! |
