Username Post: 93 Caprice 9c1 engine wiring harness firewall pass thru...        (Topic#355752)
Highlander1
Highlander1
Loc: SE North Carolina
Reg: 08-19-04
03-24-19 07:22 PM - Post#2762798
Considering using engine (to include TBI), 700R4 trans and rear axle in a 63 Sedan. The engine wiring harness enters a fixture on the passenger side firewall. The ECM is behind the passenger sided kick panel. Is the wiring harness two-part in that the firewall fixture is also a connector or is wiring harness a single/continuous assembly and the firewall fixture simply a weatherproof entry port? Any thoughts/suggestions regarding this adaptation would be appreciated. Don
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
03-29-19 06:14 PM - Post#2763221
    In response to Highlander1
The following is my recollection of late 80's - early 90's GM vehicles...
The engine wiring harness you're referencing at the firewall bulkhead connector (C100) is a two-piece affair in late model GM vehicles.
The harness "halves" are held together with a central fastener and the connector itself is filled with a nasty, gooey, grease-like substance.
Image from Third Gen F-Body dot com
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 03-29-19 06:16 PM. Reason for edit: No reason given.
Execution time: 0.119 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:51 AM
