Username Post: Is it ok to block off both heater hose fittings on the block?        (Topic#355734)
1941srodcoupe
Reg: 07-08-03
03-24-19 08:33 AM - Post#2762760
On a 1969 stock small block is it OK to block off both heater fittings on the block? I'm talking about the ones on the intake and water pump. Or does the circuit (so to speak) need to be completed for proper cooling reasons? Thanks
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
03-24-19 08:51 AM - Post#2762763
    In response to 1941srodcoupe
thousands of engines have the ports blocked or connected with a short hose to bye-pass the heater core, without a problem
Edited by grumpyvette on 03-24-19 08:52 AM. Reason for edit: No reason given.
03-24-19 07:40 PM - Post#2762801
The heater was optional on 1955 up Chevys with small blocks and both holes had a plug, if they didn't have a heater.
busterrm
busterrm
Loc: Wichita Falls, Tx
Reg: 08-31-10
03-24-19 08:38 PM - Post#2762804
    In response to acardon
In the desert regions most cars have the heater bypassed with hose bought at any parts store. The two outlets are usually different size hose, so let the assistant at the parts store know if your vehicle is that way so the bypass hose fits correctly. You might consider a bypass for the heater core also.
==== BOB ====
If I can't smoke the tires I want more!
1976 Chevy Nova
2007 Chevy 1500 1/2 ton
2017 Harley Davidson XL1200 Sportster
2018 Nissan Versa Note
454cid
Loc: West Michigan
Reg: 02-18-12
03-24-19 08:59 PM - Post#2762805
    In response to busterrm
I had a heater core blow out of town once, and I stopped by a NAPA and bought a fitting that had was 3/4" on one end and 5/8"th's on the other. I still have it tucked away in case I need it... Although, I can't tell you exactly where it is.
I think there are a few small blocks that don't have the internal bypass... 60/70's Corvettes, I think? I looked into it at one time, and it seem like it was a Corvette board where they were having issues not running a heater core. Also the late Vortec SBC has an external bypass (like a BBC) instead of the earlier internal to the pump bypass. You really neeb a bypass of some kind, and the heater circuit will function like that if there's nothing else.
99 K3500 RCLB
1941srodcoupe
Reg: 07-08-03
03-25-19 06:00 AM - Post#2762821
    In response to 454cid
Thanks for the info folks.
03-25-19 04:19 PM - Post#2762878
Many Chevys have a heater shutoff valve as part of the heater setup. Vintage Air setups do too. Heater circuit coolant flow is deadheaded if the valve is closed.
All traditional small blocks except the 96-up Vortec have an internal bypass.
Plugging the ports at the manifold and water pump is just fine, no need for a loop.
Algoma56
Reg: 03-14-05
03-26-19 06:59 AM - Post#2762932
    In response to Rick_L
Would same apply for the big blocks? They have a bypass hose at the water pump, so the heater fittings can be plugged?
03-29-19 09:20 AM - Post#2763162
    In response to Algoma56
Yes.
Algoma56
Reg: 03-14-05
03-29-19 05:39 PM - Post#2763218
Thanks. I figured so, just needed confirmation.
Execution time: 0.097 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:36 PM
