Username Post: 1941 brake upgrade        (Topic#355705)
randymo9
Reg: 03-21-19
03-21-19 08:33 AM - Post#2762588
has anyone put 53 chevy type front brake assembly on a 41 chevy coupe. looking for better brakes without converting to disc. 53's are self energizing and will help with pedal effort thanks randy
03-21-19 08:40 AM - Post#2762589
    In response to randymo9
Welcome to ChevyTalk. You can use 52-54 brakes. To keep the 6 lug you need the pickup drums, not sure of what years. Several guys have done it and will post soon.
29-41, 42-48, 49-54 Moderator
1946 Chevy 1/2 ton pickup, stock. Purchased 11/18/17. Sold 9/16/20
randymo9
Reg: 03-21-19
03-21-19 02:20 PM - Post#2762599
thanks for info randy
1971BB427
Loc: Portland,Or
Reg: 12-06-09
05-01-19 07:55 AM - Post#2765468
The pickup brakes from 1949-59 will work, and backing plates should also bolt on your earlier spindles. It would be wise to get the conversion wheel bearings to convert from ball bearings to roller bearings at the same time. And the roller bearings are cheaper than replacement ball bearings too!
Lots of guys are converting their trucks to later control arm suspension systems for street rods, so finding the original parts is usually pretty easy. I'm taking all these parts off my '59 pickup axle, and converting it to disc brakes.
1969 Suburban 2wd 350
1939 Chevy passenger coupe
1937 Austin gasser 327/TH350
Execution time: 0.138 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:44 AM
