A White Sport Coupe
Reg: 08-19-10
03-19-19 10:34 AM - Post#2762487
Hello,
Can't seem to find a fuel filter on my 2007 Chevy Colorado 2WD 2.9L engine.
Senior Chevytalk Moderator
03-19-19 11:09 AM - Post#2762489
In response to A White Sport Coupe
According to a parts search: "Strainer is inside the module assembly."
Like most modern vehicles, the strainer/filter is part of an entire assembly.
A White Sport Coupe
Reg: 08-19-10
03-21-19 12:48 PM - Post#2762598
I guess that puts it inside the fuel tank?
03-23-19 12:06 PM - Post#2762722
Unfortunately, yes. It’s in the fuel tank. On most trucks, it’s easier to use an engine hoist to lift the bed up. If a hoist is not available, a bed can be moved back or tilted enough to get the pump out.
naveen999
Reg: 04-08-19
04-09-19 02:18 AM - Post#2763866
A fuel filter is a filter in the fuel line that screens out dirt and rust particles from the fuel, normally made into cartridges containing a filter paper. They are found in most internal combustion engines. ... Fuel filters need to be maintained at regular intervals.
Edited by gchemist on 04-09-19 03:40 AM. Reason for edit: No reason given.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
04-09-19 05:20 PM - Post#2763928
In response to naveen999
FWIW, the fuel filter for '07 Colorado is not a regular scheduled maintenance item.
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari |
Edited by paulo57509 on 04-09-19 05:21 PM. Reason for edit: No reason given.
naveen999
Reg: 04-08-19
04-12-19 12:20 AM - Post#2764083
Lack of engine power. An overall lack or engine power in all gears can be due to a lack of fuel getting to the injectors. ...
Engine stalling under strain. If you find that the engine is losing power under hard acceleration or going up a steep incline, then it may be down to a bad fuel filter. ...
Random engine misfire
Edited by gchemist on 04-14-19 09:44 AM. Reason for edit: No reason given.
