Username Post: Headlights all quit at once        (Topic#355660)
95z28edwards
Loc: VA
Reg: 03-18-19
03-18-19 07:50 AM - Post#2762355
Hello I hope someone can help. Last night my headlights went out everyone at same time. My dash cluster dosen't show there on. Either and don't have power at the headlights. Every other light works as well as the turn signals and multi function switch but the dinger works like when you shut car off with headlights on. But no light. Can anyone tell me where to look. Thanks in advance
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
04-03-19 08:05 AM - Post#2763565
    In response to 95z28edwards
Looks like there is some sort of circuit breaker inside the headlight switch that could be tripped. You might check the resistance to ground at the output (yellow wire) of the switch to determine if there's a short that is causing the circuit breaker to trip. If the resistance is reasonable, you could jumper the red (input) and yellow (output) wire at the switch connector to see if the lights turn on. If the lights turn on, I'd replace the switch. I found a wiring diagram for a '95 online at:
http://shbox.com/1/headlight_chevy_199 5.jpg
elcamino
elcamino
Reg: 03-30-00
06-28-19 05:32 AM - Post#2769415
Did you put in some super powerful lights? System can't handle it.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
2016 Polaris RZR 900 EPS
Execution time: 0.377 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:00 AM
