Username Post: Mounting 61 Valance Panels        (Topic#355636)
BelAirBub
BelAirBub
Reg: 06-18-18
03-15-19 10:18 PM - Post#2762197
How did GM mount these? What hardware is used? My car came with them unattached and in sorry shape in the trunk. I just had them sandblasted today and will be refinishing them. I can see from fitting up the panels, there's probably a couple thru bolts and some sheet metal screws? What style screws? There is one screw still attached to my car that has a large washer and hex head screw. Is this the 'correct' style. I figure as long as I have to purchase hardware I will make an effort to get the right stuff.
Attachment: 20190315_220813.jpg (61.6 KB) 1 View(s)
Attachment: 20190315_220523.jpg (150.01 KB) 1 View(s)
Attachment: 20190315_220558.jpg (39.64 KB) 2 View(s)
1961 Bel Air Bubbletop
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
03-16-19 02:39 AM - Post#2762202
    In response to BelAirBub
May I suggest a 1961 Assembly Manual?
Spas602
"2nd Year" Platinum Supporting Member
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
03-17-19 10:08 AM - Post#2762299
I checked my car, came up with 5/16 bolts for the rear. I counted 14 total but I may be missing some. You also need 2 5/16 clips for corner- rear mount.
Don't forget your gonna need the rear bumper kinda loose. You will need tighten your rear bumper as last part of mounting. I'm unsure about the front valances.
Attachment: image.jpeg (2.7 MB) 0 View(s)
Attachment: image.jpeg (1.33 MB) 1 View(s)
Attachment: image.jpeg (3.16 MB) 0 View(s)
Attachment: image.jpeg (2.72 MB) 0 View(s)
Attachment: image.jpeg (1.77 MB) 0 View(s)
My CT Build Page:
http://chevyta.lk/Spas606_ImpalaBuild
BelAirBub
BelAirBub
Reg: 06-18-18
03-18-19 06:44 AM - Post#2762349
    In response to Spas602
Thanks Spas. That conforms the fastener I have is right for the rest of the holes. Appreciate your helpful response! Also thanks for the tip on loosening the bumper.
Edited by BelAirBub on 03-18-19 06:45 AM. Reason for edit: No reason given.
Verne_Frantz
61-64 Subject Matter Expert
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
03-18-19 08:46 AM - Post#2762366
If the bumper isn't tweaked, I've had good results removing all the screws with a 1/4" ratchet and a small socket.
Verne
Execution time: 0.094 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:05 AM
