Username Post: Looking to Get a 3 Speed (for Column Shift) with Overdrive        (Topic#355634)
Chevrolla67
Chevrolla67
Loc: St. Petersburg, Florida
Reg: 01-14-07
03-15-19 07:23 PM - Post#2762179
Probably getting 3 speed with OD tomorrow from an older gentleman that has had it out of a vehicle for about 20 years. What should I keep an eye out for or be looking at when I go pick this up. Anyone in know of someone to go through one of these? Live in Pinellas County Florida.
Edited by Chevrolla67 on 03-15-19 07:28 PM. Reason for edit: No reason given.
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
03-15-19 07:56 PM - Post#2762186
    In response to Chevrolla67
The pre65 3speed OD was not 1st gear synchronized. The later years OD were Saginaw's with synchronized 1st gear. The OD unit from the 3 speed can be installed onto a Saginaw 4 speed transmission with a little work.
mcdarrunt
Reg: 11-07-18
03-15-19 10:10 PM - Post#2762196
    In response to aghaga
One thing to check for is that the solenoid works as they are pricey to buy or have rebuilt. A battery and a couple jumpers will let you hear them "click".
Chevrolla67
Chevrolla67
Reg: 01-14-07
03-16-19 09:01 AM - Post#2762225
Thank you for the info. I actually picked it up early this morning. I guess I will have to try that now. Everything looked great on the transmission and shifted great. Reverse did click it out of OD which is what someone else said to check as well.
Edited by Chevrolla67 on 03-16-19 09:02 AM. Reason for edit: No reason given.
Chevrolla67
Chevrolla67
Reg: 01-14-07
03-16-19 09:04 AM - Post#2762226
Thank you for the into. I do believe this is a Pre-65 so was by previous owner that 1st is not synchronized. Not a big deal to me. i do find it interesting about the 4-speed idea but keeping mine on the column, that idea would not work.
Chevrolla67
Chevrolla67
Reg: 01-14-07
03-16-19 09:09 AM - Post#2762228
Curious to know what is the best place to find a simple wiring diagram. This transmission actually has the pigtail hookup that has a "governor" (term owner used) on the OD side of the transmission. i do not plan on hooking a pigtail to it because i do not have anything hooked to the carburetor. I think I just need to hook up the electric part of the OD to a toggle (hidden under dash). As a safety, he preferred I use a cable to be able to manually engage or disengage the OD. Does this sound like I am on the correct path?
Execution time: 0.061 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:30 AM
