Username Post: Frustrating no-start, no-restart issue        (Topic#355626)
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
03-15-19 10:39 AM - Post#2762148
I have a 1953 3100 ½ ton truck with its original 216 engine. Carburetor is a Rochester “B”, also original to the truck, with the thicker top flange first introduced in the 1952 model year. The truck will not start unless I either use starting fluid (which I don’t like to do) or manually fill the float bowl with fuel. With fuel or ether, it starts right up, and runs great. This condition exists when the truck is cold, as well as when it has been run but has been sitting for any amount of time.
I have read up on the “usual” issues with these things, and have addressed them as follows:
Starter. Spins pretty well with an Optima 6-volt battery providing juice.
Starter cables. Heavy ("0" gauge). Custom made from welding cable.
Timing. I have it set per spec, to the point that it neither bogs nor spark-rattles.
Carburetor. Rebuilt by the premier Rochester specialist in the VCCA. Phenolic spacer is installed. Mixture adjusted with exhaust gas meter.
Fuel. I have been using strictly non-ethanol gas since I put the truck together, about 5 years ago.
Manifold heat valve. I have it wired shut, i.e. no hot air from exhaust manifold toward intake.
Running temperature. Temp gauge stays at 180, as it always has.
I can’t believe these trucks acted like this when they were new – otherwise, Chevrolet couldn’t have sold as many as they did in the 1950s.
Any ideas? I’ve been working on Chevrolets for 40 years, but never one this old, and it has me stumped. I would be grateful for any help.
1953 3104 1/2 Ton Truck
1965 Impala SS 327/M20
1965 Chevelle SS 327/M20
VCCA #47487
AACA #446449
ALPCA #12906
Edited by bajones238 on 03-15-19 11:51 AM. Reason for edit: No reason given.
03-15-19 01:10 PM - Post#2762152
    In response to bajones238
Does the accelerator pump squirt when this occurs? Also, pull the carb, set it on the bench atop some newspaper, see if it leaks fuel over night.
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
03-15-19 02:22 PM - Post#2762155
Thanks for getting back to me. Accelerator pump works (when there is fuel in the bowl). I will pull carb & check for leakdown. Your post makes me wonder if fuel is siphoning back to the fuel pump - glass bowl is completely full.
VCCA #47487
AACA #446449
ALPCA #12906
03-15-19 04:48 PM - Post#2762162
if the fuel level in the bowl is below the needle and seat, siphoning shouldn't occur. Take the carb top off, fill it up and see if it leaking down somewhere overtime. Careful with fuel though, maybe alcohol is safer.
Ray P W
Reg: 09-30-15
03-16-19 10:18 AM - Post#2762232
bajones,
Even with the float bowl completely empty it should fill back up with engine cranking unless there is a problem with the fuel pump.
I drive my restored '36 Chevy pickup only every couple of weeks and each time the gas is evaporated out of the fuel bowl. Then it refills from engine cranking and the engine starts.
Ray W
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
03-16-19 12:27 PM - Post#2762238
    In response to Ray P W
Good suggestions all, I will investigate and advise.
VCCA #47487
AACA #446449
ALPCA #12906
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
03-18-19 08:14 PM - Post#2762431
This is normal with todays gas, ethanol or not. Pull the choke alll the way out and crank over, giving apump with the gas pedal after about 15 seconds.
bajones238
bajones238
Loc: South Carolina
Reg: 06-19-11
03-19-19 09:06 AM - Post#2762476
    In response to Gene_Schneider
Well, that's one method I've never tried. I will try this before I start taking anything apart. Thank you Gene, good advice as always.
[Update]
It took a little longer than 30 seconds, but the truck started after cranking a lot longer than I would have thought necessary. It looks like, even with the non-ethanol gas, the fuel boils off completely when the truck has been running and then sits.
Interestingly, after full warm-up and a long drive, with coolant temp gauge indicating about 180 degrees, here are the other temperatures I observed (using a Fluke "59 Max" IR thermometer):
Intake manifold under carburetor: 160 degrees
Exhaust manifold under intake and carburetor: 270 degrees
Carburetor fuel bowl: 107 degrees
After sitting two hours, temperature of the fuel bowl dropped to 83 degrees, but by then, the fuel was apparently gone. So I guess today's non-ethanol boils at 107 degrees. Various technical articles put boiling point as low as 95 degrees for "winter" blend, so that seems reasonable. I'd be interested to know if any other owners of original-spec Advance Design trucks are having the same experience.
VCCA #47487
AACA #446449
ALPCA #12906
Edited by bajones238 on 03-19-19 11:25 AM. Reason for edit: No reason given.
Execution time: 0.066 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:47 AM
