Username Post: '56 Gas Tank Sending Unit        (Topic#355610)
George56
Loc: Miami, Fl
Reg: 03-16-16
03-14-19 08:44 AM - Post#2762062
Do you have to lower the gas tank to install
the new sending unit?
chevyman57B.C.
Reg: 08-29-12
03-14-19 10:32 AM - Post#2762070
    In response to George56
NO just alittle tougher to get it removed but it can be done I have done it this way before. Just jack up the rear end as high as you can and remove the screws wire and gas tank unit there is plenty of room if you are skinny LOL
Larry
ROUTE 55
ROUTE 55
Loc: Minnesota
Reg: 05-17-07
03-17-19 08:52 AM - Post#2762292
I replaced mine while the car just sat on the garage floor.
It wasn't that bad - it took me about an hour. I needed a clutch-head socket set (or C.H. screwdriver) on my '55.
I assume that you'll need the same on a '56. If you don't have one, you could probably use a vice grip or even grind a large screwdriver or a hex bit to fit the clutch-head screws.
Dave
55 Belair HT 396-L78 BB, 4sp Muncie, 12 bolt Posi.
Execution time: 0.083 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:51 PM
