Username Post: Clutch pedal sticking        (Topic#355608)
dtwbcs
dtwbcs
Loc: College Station,Tx
Reg: 04-19-10
03-14-19 04:11 AM - Post#2762041
1960 Bel Air clutch pedal not returning from floor.
Don't know why it is sticking to the floor and not returning. Is it the over limit spring worn?? Is there a spring that I can buy?Called Ecklars but they don't have one.
Any advice?
Danny
1960 BelAir 4dr sedan, original 235engine,3/4cam(Patricks '),848head,Clifford intake&Fenton headers,Wayne valve&side cover,BeeHiveOil filter,Langdon's HEI set-up,3spd MANUAL OD trans,
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
03-14-19 04:24 PM - Post#2762089
    In response to dtwbcs
Try adjusting the clutch so it engages lower. If that doesn’t work, make the engagement higher. These things are fussy , so do the adjustments in small increments.
Member #2194
dtwbcs
dtwbcs
Reg: 04-19-10
03-15-19 04:41 AM - Post#2762117
    In response to DonSSDD
That's not going to stop the pedal from getting stuck on the floor.
-I need a solution to stop this-
Danny
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
03-15-19 06:37 AM - Post#2762126
Have you inspected the pedal, push rods (upper and lower), the z bar, fork, etc, for damage/obstruction/bindin g?
Does the disc separate from the flywheel when clutch is depressed?
The clutch diaphragm 'spring' provides the force to hold the clutch disc to the flywheel. It also does the heavy lifting for returning the pedal. The 'other' (there're two on my '63, a '60 may be a little different) springs do mostly anti-rattle duty.
Pete
DonSSDD
DonSSDD
Reg: 08-21-01
03-15-19 07:36 AM - Post#2762134
Try it, it worked for me on my 59.
The big over center spring under the dash on the 59 and 60 is usually the cause of this, That spring relduces leg pressure when you have the pedal to the floor, they did away with it in 61, I always wondered if you could remove it and let the pressure plate do the work as with later years.
Member #2194
dtwbcs
dtwbcs
Reg: 04-19-10
03-16-19 04:32 AM - Post#2762205
I think I will try a stronger clutch return spring first.Replaced the z bar awhile ago.took it to one shop and he welded a bolt underneath the pedal.Took to another shop and that guy cut off the bolt and adjusted the clutch pedal;which only lasted a short while.
Danny
dtwbcs
dtwbcs
Reg: 04-19-10
03-17-19 06:55 AM - Post#2762289
I put a stronger return spring.Definitely helped.
THANKS
Danny
Execution time: 0.062 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:02 AM
