Username Post: Powder Coating Quote        (Topic#355607)
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
03-14-19 03:54 AM - Post#2762040
I have never had anything powder coated before. Any idea what a reasonable quote would be to have A/C and alternator brackets powder coated?
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
03-14-19 05:53 AM - Post#2762046
    In response to kingkreeton
Most commercial powder coat companies have a minimum, usually $100-150 around here (North Texas). So you might want to round up a couple dozen more pieces to do, like bumper brackets or suspension parts, it's like getting them done for free.
Jalapeno
lone star
Reg: 08-24-08
03-14-19 05:55 AM - Post#2762047
I have original 283 brackets powdercoated gloss black. Unused sincr powdercoat. Im in houston area
junky
Loc: Northeast CT
Reg: 06-27-10
03-14-19 09:24 AM - Post#2762066
I had a lot of my Corvair engine sheet metal powder coated, and most of the cost was in the preparation. I had fully degreased the parts, but they all needed to be sand blasted. If you can provide the parts to the powder coater in bare metal, and tell him that you are in no rush, he can do them when he is doing another black project. This is what I have done when I need only one or two pieces done. Price is very reasonable. A lot of the cost is in set up and clean up, when there is a color change. I usually go with a semi gloss black, and it is his standard black, so most times, I get the part back quickly.
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
03-14-19 04:16 PM - Post#2762086
Had all my stuff done by the place down in Dickenson off 45.
Brackets, pulleys, inner fender wells, rad support, a frames and more.
Like jalopena says take a hand full of items.
Like junky said, degrease and blast the parts yourself, although they do glass bead the parts but it's just a quick blast.
as cheap as I am, I was not offended when I was told the price.
VC56S 2 door Sedan, 39 Years
[image]http://www.chevytalk.org/fusionbb/fbbavatars/a v-3564-1354211547.jpg[/image]
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
03-14-19 06:43 PM - Post#2762097
    In response to Jalapeno
Ya, that is about $100 more than I want to spend. Unfortunately I don't have any additional parts to have done. The parts came bare metal already so prep work won't be necessary. I've called 3 places that are located near me left 3 voicemails. 0 calls back so far. Just may be a sign for me to paint them and if I want to get it done later do it another time. I'm a pretty big fan of customer service so when a company doesn't offer it upon first impression, I usually move on.
Thanks for everyone's feedback.
Shane
64 Impala SS:
4 Speed Muncie
SS540
SS540
Loc: Down in Texas
Reg: 03-29-03
03-15-19 05:51 AM - Post#2762122
Have you tried Allied Powder Coat? They did the 59 frame for $550 and have done many soda machine parts for me. But, they do have a minimum charge.
Wayne & Sherri Scott
59 Biscuit LS3 Restomod
03-15-19 07:20 AM - Post#2762131
    In response to SS540
Also beware there are bad powder-coaters out there. I'm working on a historical house that is being rebuilt. It was built before WW2 in So. Cal. and was built with the old steel casement windows. The owner wanted to add an addition and hired me to build 23 casement windows in the same style. We bought several tons of old steel windows and I started cutting them apart and welding them into the configurations the owner wanted. At the end we had 54 steel casement windows and the owner had them alllll hauled off to the powder coating place.
They came back a beautiful gray color. And if you so much as touched a screwdriver to them the powder coating chipped. Withing several days almost every window had been badly chipped in multiple places before they had even been installed. You could tap the windows with just about anything and the coating would chip. So off they went to a second powder coating place and the 2nd place did a great job.
junky
Loc: Northeast CT
Reg: 06-27-10
03-15-19 07:57 AM - Post#2762136
There are two different type of powder coats. One will chip, and the other, you can beat it with a hammer, and only dent the metal. This is why it is important to ask questions first, not after the job is done.
03-15-19 05:29 PM - Post#2762167
    In response to junky
What would the value be to a powder coat that chipped?
junky
Loc: Northeast CT
Reg: 06-27-10
03-15-19 07:41 PM - Post#2762180
It has no value to me, but there must be some applications, where it is desired.
gofastwclass
Loc: In the garage
Reg: 08-19-14
03-15-19 08:05 PM - Post#2762187
I'm no expert on this but I don't think chipping would be a desired finish as much as a by product of two potential things: 1. poor surface prep and / or 2. poor choice of product for the desired application.
The times I've talked to or worked with people getting things powder coated the guy always wanted to know what the part was or did. It wasn't until a friend started buying powder directly from the manufacturer that we understood why. There are many types of powders available depending on desired surface finish, chemical or UV resistance, etc.
A bit of quick reading explains some of the differences. Types of Powders
1961 Impala mild custom build
Gofastwclass on YouTube
Why buy when you can build it better?
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
03-16-19 06:01 AM - Post#2762210
I've pretty much decided to just rattle can these parts. They are brand new bare metal A/C and Alternator brackets made by Alan Grove Components.
I've never painted any engine components before. Any recommendations on spray paint brands? Is high temp paint necessary? How many coats would you recommend?
Shane
64 Impala SS:
4 Speed Muncie
gcrkfrd
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
03-16-19 08:07 AM - Post#2762221
try a can of that vht ceramic engine paint, it surprised me how tough it is.
junky
Loc: Northeast CT
Reg: 06-27-10
03-16-19 10:10 AM - Post#2762231
From memory, some of the brackets were painted engine color (orange) and others were painted black. Do your research before painting, so you get the colors correct.
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
03-16-19 11:07 AM - Post#2762234
I've always painted Alan Grove A/C brackets black just like the originals.
Stittville Ed
Reg: 01-10-16
03-16-19 01:53 PM - Post#2762243
Just make sure everything is very clean.
Your new parts might need just a wipe down with a solvent.
ragtp66
ragtp66
Reg: 12-09-07
03-16-19 02:21 PM - Post#2762247
I use a place called CPC here they are literally less then a five minute drive from my house. He will sandblast and powdercoat a bare frame for $300 any color. They do wheels for $50/single color. Control arms, springs, crossmembers are usually $25 each. http://www.cpcpowdercoating.com/ Granted you would have to pay shipping both ways but if you have a box full of small stuff it would probably be well worth it.
Toys:
1987 Sea Ray Pachanga 22
MrImpalaMan
MrImpalaMan
Loc: Jefferson City Mo
Reg: 10-16-12
03-17-19 04:59 AM - Post#2762280
I used Krylon Satin on my engine brackets. I followed the directions on the can exactly. Turned out nice.
Paul
1964 Impala SS 327 4 speed
gofastwclass
Loc: In the garage
Reg: 08-19-14
03-17-19 06:03 AM - Post#2762284
I prefer Rust-Oleum automotive spray paint for a durable finish on small jobs where I'm not using true 2K paint. Their paint covers very well, lays out smooth and looks great when applied properly.
The stuff takes a very long time to dry so read the instructions and plan for that. The up side is the finish has high durability like 2K automotive paint.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
03-17-19 06:14 AM - Post#2762286
    In response to gofastwclass
So I don't need to worry about getting the high-temp stuff? Thanks
Shane
64 Impala SS:
4 Speed Muncie
gofastwclass
Loc: In the garage
Reg: 08-19-14
03-17-19 07:06 PM - Post#2762328
I've had good luck with it on everything I've tried including brackets mounted directly to the engine block. The key like anything is prep, following the instructions and application. Keep in mind it dries SLOW - like hours slow on a warm day in the sun so allow for that.
shoeboxpaul
shoeboxpaul
Loc: New Freedom, PA
Reg: 08-15-16
03-18-19 12:52 PM - Post#2762391
Powder paint is only as good as the surface being coated. I know you are not considering a casting but, keep in mind that used castings are porous and can hold oil, even after blasting, cleaning, baking, re-cleaning and a soak in a phosphate solution and/or a rust inhibitor. The surface has to be blasted with aluminum oxide or anything that will give tooth, something glass bead does not. I use polyester TGIC powders and they are the most common, and most durable. I have never had an issue with it chipping when prep and baking temps are done properly. The painting and the baking are the easiest parts of the entire process. Preparation of surface is critical if you want the paint to last. Harley-Davidson motorcycles are powder coated - tanks, fenders, frames, brackets, etc. - and it is tough as nails. Of course, this is new metal and I am trying to point out that used parts take more preparation. Sounds like the casement window frames in this thread were done by a fly-by-night outfit. The name of the company should be posted so no one else gets stung.
Personally, I love powder paint better than plating or painting. I can clean a small part, blast it, bake it and put the part in use as soon as it cools to touch. Paint has to dry/cure. Zinc is sacrificial, chrome eventually gives up and finding anyone that does cadmium plating usually involves shipping. Arsenic is used in the cad plating process. Arsenic and the EPA do not mix. If you need cad plating done, Google Delta Specialty Coatings, Houston, TX and give them a call. here is a link:
http://deltaspecialtycoat ings.com/capabilities.php
Edited by shoeboxpaul on 03-18-19 12:56 PM. Reason for edit: No reason given.
Execution time: 0.095 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:56 AM
