Username Post: rear quarter panel logos        (Topic#355598)
jrhopkins
Loc: washington state
Reg: 12-23-16
03-13-19 12:12 PM - Post#2761995
wanting to remove the crossed flag and Impala logo from the rear quarter panelon a 1960 impala. do I have to remove the rear seat and interior panel to get to the screws?
Edited by jrhopkins on 03-13-19 12:46 PM. Reason for edit: No reason given.
Chevyfan60
Chevyfan60
Loc: Longmont, CO
Reg: 04-19-01
03-13-19 03:01 PM - Post#2762010
    In response to jrhopkins
That sounds about right. I have a '60 Impala 4-door sedan so I removed the rear door panel to get to them. The crossed flag emblem is pressed in with small clips but not easy to get out, I was afraid of damaging it so getting at it from the back helped. The "Impala" emblem was held on with speed nuts.
Michael
1960 Impala 348, 1960 El Camino (x2), 1960 Nomad, 1992 S-10 Blazer, 2001 GMC Sierra 2500HD,
2002 Trailblazer
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
03-13-19 03:27 PM - Post#2762013
I have attached pictures of the items if this is what you are talking about. This is on my '60 Impala 2drht, and they are attached with small clips and the pieces just push on. Hope that this helps. Lamar
Attachment: DSC06152.JPG (123.61 KB) 0 View(s)
Attachment: DSC06160.JPG (1.16 MB) 2 View(s)
Attachment: DSC06170.JPG (1.26 MB) 1 View(s)
jrhopkins
Reg: 12-23-16
03-13-19 04:14 PM - Post#2762015
    In response to PLS
PLS_
so the clips are pressed onto the emblem mounting posts and then the piece is pressed into the holes in the fender? your picture shows the same procedure for the crossed flag logo and the "Impala" script. I just didn't want to try prying on them without knowing what I was doing. I have to remove the seat and inner panels anyhow and thought that would be easy to get to them.
PLS
PLS
Reg: 06-07-12
03-13-19 05:26 PM - Post#2762021
I installed the clips then the pieces. Yes my clips are similar for both pieces. With the quarter window access panel removed will definitely help with removing them.
Jens
58-60 Subject Matter Expert - "11th Year" Silver Supporting Member
Jens
Loc: Iowa.
Reg: 04-21-02
03-13-19 06:05 PM - Post#2762023
    In response to PLS
Yes the emblems pry out from the front side. 2 different barrel clips that push into the body and the emblems push into the clips. If the emblems are stubborn to get out you can spray a little penetrating oil on the pegs to relieve surface tension before prying them out.
Attachment: IMG_2752_4798_.jpg (342.1 KB) 2 View(s)
Attachment: IMG_2746_4795_.jpg (363.9 KB) 3 View(s)
jrhopkins
Reg: 12-23-16
03-13-19 06:20 PM - Post#2762025
    In response to Jens
lots of thanks everyone. think i'll wait to pull out the seat to remove them. the car was restored some years ago and I tried prying on one of the flag emblems and heard something fall on the inside of the panel so they may have been attached at some time with something on the inside, you never know!since i'm taking the rear seat out anyway that will make it easier I hope.
Execution time: 0.061 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:31 AM
