Username Post: Timing for mild RV Cam        (Topic#355593)
Schiavoneluke
Reg: 05-16-16
03-12-19 08:24 PM - Post#2761966
Should the timing for a stock 327 with an rv cam be different from spec? I had total advance between 28 and 32 (32 initially) and actually found it to idle smoother by retarding it slightly (29/30) but I dont like retarding the timing, I thought that if anything the timing should be more advanced for the cam. Any thoughts?
03-12-19 10:00 PM - Post#2761971
    In response to Schiavoneluke
every engine is different. so is evry driver. you need to tune it to how you drive. timing marks are meaningless unless you have a pinned and verified balancer ring.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
03-13-19 06:59 AM - Post#2761978
Perhaps this will help:
https://www.chevelles.com/forums/13-performance /18...
Pete
notcamero
Reg: 08-02-03
03-17-19 06:42 PM - Post#2762325
    In response to japete92
An Edelbrock Performer cam is a sort of RV cam, advanced intake and specs for stronger mid range. Timing sets at 14 degrees initial. You can change the vacuum advance for port vacuum to cut advance at idle, will go to full advance when the carb is opened up some.
Execution time: 0.058 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:32 AM
