Username Post: 1953-1954 Gauges - again        (Topic#355581)
Snegrah
"2nd Year" Platinum Supporting Member
Snegrah
Loc: Pacifica, CA.
Reg: 04-28-04
03-11-19 03:07 PM - Post#2761857
Gents,
I have nice stock gauges that I (think I) want to reinstall vs the aftermarket ones. My car now has a 350 V8 and 12v system. I'm going to re-decal them and install new glass in the cluster.
FUEL GAUGE:
I have the 12v to 6v resistor for the fuel gauge. The photo shows a red tag for the sending unit and a fuse holder attached to the hot side. Should I keep the fuse holder when I install the resistor? If so, what value fuse?
TEMP GAUGE:
I'll need a new longer capillary tube to go the the front of the intake. Who rebuilds these temp sending units?
AMP GAUGE:
It looks almost new on the inside. Do I have to do something different when I go to 12v? I know voltmeters are better but amp gauges have been around for a while so, I'll stick with it. Yes?
OIL GAUGE:
I have the 60lb pressure gauge so, just a new line and it's good to go.
Any info and thoughts are appreciated.
Thanks,
Tom
Attachment: 20190310_135043__Small_.jpg (222.14 KB) 4 View(s)
Attachment: 20190310_135050__Small_.jpg (190.56 KB) 2 View(s)
Attachment: 20190310_134845__Small_.jpg (244.47 KB) 0 View(s)
Attachment: 20190310_134804__Small_.jpg (206.18 KB) 1 View(s)
Attachment: 20190310_134816__Small_.jpg (111.43 KB) 0 View(s)
51 Chevy Bus. coupe 261 6cyl 5 speed
53 Chevy Bus. coupe 350/700R/AC
49 Chevy P.U. 350/700R/AC
51 Chevy sedan delivery - project
Chevs of the 40s
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
03-12-19 05:00 PM - Post#2761958
    In response to Snegrah
For the Temp, it is extremely costly to have that capillary tube modified so I was told to use a gauge from a '56 with the corresponding sender. While it takes a little farting around to make them fit, they look the same and are electric. I cant post pics here so I will email them to you to show you how I did it. Mine doesn't read correctly yet as I'm pretty sure I did something wrong since I was assured by a few people this was the way to go.
lobucrod
lobucrod
Loc: Springtown Texas
Reg: 10-01-07
03-15-19 05:10 AM - Post#2762119
Below is a link to a procedure for replacing a broken or missing capillary tube. The same process could be used to make an existing one longer.
https://www.jalopyjournal.com/forum/threads/capill...
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
Chevs of the 40s
Execution time: 0.265 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:55 PM
