Username Post: Heavy Duty Rear Axle Assembly        (Topic#355573)
tmcfadden932
Gold Supporting Member
tmcfadden932
Reg: 03-11-19
03-11-19 12:21 PM - Post#2761842
Ford 9 inch Rear axle assembly with a nodular iron case. Setup for 55 thru 57 with a frame pocket kit installed. 58 inches from face to face, 11 inch drum brakes with metallic brake linings, E-brake cable attached, 3 by .5 inch hardened lug bolts, 5 on 4.75 inch pattern, 3.50 gear with TracLock limited slip, 28 spline axles. U-bolt mounting hardware included. Will support 275-60R15 tires on 8 inch wide wheels with 5 inch back spacing. Asking $900, make offer.
Attachment: 9inchRearSmall.jpg (41.88 KB) 7 View(s)
Edited by tmcfadden932 on 03-11-19 12:50 PM. Reason for edit: No reason given.
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
03-11-19 12:53 PM - Post#2761843
    In response to tmcfadden932
Where are you located?
tmcfadden932
tmcfadden932
Reg: 03-11-19
03-15-19 08:35 AM - Post#2762139
    In response to Mel Foye
California, south of Sacramento in Manteca Ca.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
03-15-19 05:26 PM - Post#2762166
5 years ago, I would have been all over this, even though I had a 57 Olds, Complete rear end , with both a 4,88 and 5.38 Positraction 3rd members, and Summers Brother's axles, (Eaton style, NOT the Dana style that were weaker), and already with the spring pads moved. But, I sold everything, thinking I'd never use it! C'est la vive, as they say. Should have kept it, but I did't have the room! Sold it all at a loss, but that's how this car deal goes, right? TONY, this is ONLY an ad, he's never posted ANYTHING to Chevy Talk; I say delete him, and his ad, that's NOT what Chevy Talk is all about. JMO! I am Butch/56sedandelivery.
Edited by 56sedandelivery on 03-15-19 05:32 PM. Reason for edit: No reason given.
Mel Foye
Mel Foye
Reg: 09-29-00
03-15-19 06:35 PM - Post#2762174
Butch I have been away too long so school me on this type of ad. I did not mean to respond to something that went against any rules but it just slid through my brain as a Ford rear end for a 55-57 Chevrolet in the 55-57 section. Thanks Mel
Truthfully I did not go over the rules I just --reupped-- and started typing.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
03-15-19 07:13 PM - Post#2762178
YOU did't place the ad. There are rules, but no one here gets too bent out of shape if they're not followed to the letter. Some guys come here ONLY for placing their ads; that's a little different. Tony would take care of things if it was too "out-of-bounds". I only responded to showcase my own stupidity at times! I am Butch/56sedandelivery.
Edited by 56sedandelivery on 03-15-19 07:16 PM. Reason for edit: No reason given.
tmcfadden932
tmcfadden932
Reg: 03-11-19
04-05-19 12:48 PM - Post#2763699
I do not mean to offend anyone but if there are rules, please direct me to that site. I saw "FREE 55-57 Classified Ads Free" and posted a assembly there. I am sorry, what was the specific problem?
SOLD
Edited by tmcfadden932 on 04-22-19 01:41 PM. Reason for edit: No reason given.
Execution time: 0.296 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:55 AM
